[Mapserver-users] Ccoordinate/projection display problem?
Ed McNierney
ed at topozone.com
Fri Sep 12 14:00:45 EDT 2003
Ann -
You need to specify a PROJECTION block for your MAP object (at the top level) as you have, AND you need to specify a PROJECTION block inside each layer with a source in a projection different than the output map. The example below has PROJECTION blocks in the right places, but you're not specifying that raster layer is in UTM - you're saying that the output map, the shapefile, and the raster layer are all in the same lat/lon projection.
Your EXTENT also needs to be in the same units as the top-level (output) projection, so it should be in degrees for lat/lon and meters for UTM; you should also add a UNITS DD or UNITS METERS as appropriate to avoid problems with scalebars, etc.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
Sent: Friday, September 12, 2003 1:20 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Ccoordinate/projection display problem?
The short description:
I have two layers, one geotiff, one shape. The geotiff, a shaded relief
base map, appears to be in UTM. The shape, a file of state boundaries,
appears to be in latlon. I think I have proj installed properly, but
I've thought that before. I've tried many variations of the map file
with either the shp projection or the raster projection.
In raster projection:
Raster plots, shape does not.
In shp projection:
Shape plots, if it is the only layer.
Plot is totally grey if both layers are included.
Also using the epsg specification instead of the detail never works.
Would anyone suggest a way to test the proj installation outside of
mapserver?
Thanks-
Ann
The details:
mapserver
[akeane at pinky ]$ ./mapserv -v
MapServer version 4.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
map file
NAME TEST
#EXTENT -84.0 36.0 -59.0 49.0 # shp extent
# EXTENT -6086629.000 -2784239.000 4279371.000 4488761.000 # full raster
extent
EXTENT -6629.000 -1084239.000 3079371.000 988761.000 # local raster extent
SIZE 400 300
SHAPEPATH "/httpd/www/programs/2004/neaqs/surface/dyn/data"
DEBUG on
WEB
LOG "/httpd/www/programs/2004/neaqs/surface/dyn/out.log"
END
#PROJECTION
# # shp projection
# "proj=latlong"
#END
PROJECTION
# raster projection
# "epsg:4326"
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
LAYER # States
NAME "states"
# source http://nationalatlas.gov/statesm.html
DATA statesp020
STATUS DEFAULT
TYPE POLYGON
CLASS
COLOR 220 220 220
OUTLINECOLOR 255 0 0
END # end of class object
DEBUG on
PROJECTION
"proj=latlong"
END
END # end of layer object
LAYER # Shaded Relief Raster
NAME "relief"
# source http://nationalatlas.gov/shadedm.html
DATA "/httpd/www/programs/2004/neaqs/surface/dyn/data/shdrlfi020l.tif"
STATUS DEFAULT
TYPE RASTER
DEBUG on
PROJECTION
# "epsg:4326"
"proj=longlat"
"ellps=WGS84"
"datum=WGS84"
"no_defs"
END
END
Raster file
[akeane at pinky data]$ gdalinfo shdrlfi020l.tif
Driver: GTiff/GeoTIFF
Size is 10366, 7273
Coordinate System is:
PROJCS["unnamed",
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.2572235629972,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",45],
PARAMETER["longitude_of_center",-100],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (-6086629.000000,4488761.000000)
Pixel Size = (1000.000000,-1000.000000)
Metadata:
TIFFTAG_IMAGEDESCRIPTION=Color shaded relief of North America
TIFFTAG_SOFTWARE=USGS DRG production software
TIFFTAG_DATETIME=2003:02:06 13:19:34
Corner Coordinates:
Upper Left (-6086629.000, 4488761.000) (156d 3'31.10"E, 37d45'55.65"N)
Lower Left (-6086629.000,-2784239.000) (154d27'44.36"W, 3d 2'12.16"N)
Upper Right ( 4279371.000, 4488761.000) ( 4d 0'23.08"W, 53d59'22.66"N)
Lower Right ( 4279371.000,-2784239.000) ( 61d 9'32.19"W, 11d18'12.56"N)
Center ( -903629.000, 852261.000) (113d12'19.80"W, 51d59'8.84"N)
Band 1 Block=10366x1 Type=Byte, ColorInterp=Red
Band 2 Block=10366x1 Type=Byte, ColorInterp=Green
Band 3 Block=10366x1 Type=Byte, ColorInterp=Blue
shp file
[akeane at pinky data]$ ogrinfo statesp020.shp statesp020 | more
INFO: Open of `statesp020.shp'
using driver `ESRI Shapefile' successful.
Layer name: statesp020
Geometry: Polygon
Feature Count: 2895
Extent: (-179.133392, 17.674692) - (179.788208, 71.398048)
Layer SRS WKT:
(unknown)
AREA: Real (12.3)
PERIMETER: Real (12.3)
STATESP020: Integer (11.0)
STATE: String (20.0)
STATE_FIPS: String (2.0)
OGRFeature(statesp020):0
shp metadata
Spatial_Reference_Information:
Horizontal_Coordinate_System_Definition:
Geographic:
Latitude_Resolution: 0.000278
Longitude_Resolution: 0.000278
Geographic_Coordinate_Units: Decimal degrees
Geodetic_Model:
Horizontal_Datum_Name: North American Datum of 1983
Ellipsoid_Name: GRS1980
Semi-major_Axis: 6378137
Denominator_of_Flattening_Ratio: 298.257222
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
