[Mapserver-users] Adding feature
Liz Godwin
godwinl at agr.gc.ca
Wed Sep 17 09:25:50 EDT 2003
Jan,
If I read correctly in your post, you're using
&map_Map1_feature_new...
To get mapserver to add a feature via CGI, you must first define a
layer in the mapfile (say Map1) that contains all the symbology etc, but
without a data definition.
For example:
LAYER
NAME "Map1"
STATUS DEFAULT
TYPE POINT
CLASS
SYMBOL "circle"
SIZE 5
color 255 0 0
END
PROJECTION
#insert your projection info here
END
END
CGI variables for the point would be:
&map_Map1_feature=new (equals sign not underscore)
&map_Map1_feature_points=110840+414533 (this point is in Map1's
projection if defined)
for more info there is documentation for this. It's at the bottom of
the page:
http://mapserver.gis.umn.edu/doc40/cgi-reference.html
Cheers,
Liz
>>> <jan.espenlaub at uuc.de> 09/17/03 05:17AM >>>
Dear Mapservers!
After searching the archives without much success I have to ask the
community for help: I am trying to add features to a Map. Regardless of
the method I am using
(CGI-Variable a la:
"http://server/scripts/version40/mapserv.exe?map=c:/inetpub/wwwroot/
workshop/workshop.map&mode=map&layer=Map1&map_Map1_Featur
e_new..."
or inline in the Mapfile:
LAYER
NAME Map2
TYPE point
STATUS ON
DATA "c:\inetpub\wwwroot\workshop\data\demo.shp"
DEBUG ON
FEATURE
POINTS 110840 414533 END
END
CLASSITEM 'id'
CLASS
NAME "Brunnen"
EXPRESSION /./
SYMBOL 'star'
SIZE 10
COLOR 255 125 1
TEMPLATE "queries/point.htm"
END)
All I get is the following
message :
"CGI Timeout
The specified CGI application exceeded the allowed time for
processing. The server has deleted the process."
The Webserver (IIS 5) logs a 502-Error (i.e Bad Gateway request)
Any Ideas?
I have tried the same thing on different servers (IIS 4) on our
network with the same "success". The mapfile without
FEATURE works fine. So do the CGI-Variables without
"feaure_new".
Thanks in advance
Jan Espenlaub
PS Is there any help to be expected from the different DEBUG-
Flags in the Mapfile? The log looks just the same with or without
them.
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
