[Mapserver-users] Re: problem getting bounds of poly shape
pkishor_98
pkishor at geoanalytics.com
Sun Sep 21 14:02:30 EDT 2003
replying to my own question -- I might not be drawing a correctly closed shape...
hence no legit rectObj. Corollary question -- do I have to explicitly close a shape to
make a legit poly? Assuming the answer to that is a resounding "yes", is there a way
to test whether a shape is a legit poly other than attempting to get its bounds and
seeing if anything is returned?
--- In mapserver-users at yahoogroups.com, "pkishor_98" <pkishor at g...> wrote:
> I am drawing a shape on a poly layer like so...
> my $shpObj = new mapscript::shapeObj($mapscript::MS_SHAPE_POLYGON);
> adding a few lines with points (of course) and drawing it. The shape is drawing fine
> and showing up on the graphic, but I can't get its bounds.
> The bounds show up as -1 -1 -1 -1 via $shpObj->{bounds}->{minx} etc. I am at
my
> wits end here... any idea what is going on?
> Tia.
> Mapserver-users mailing list
> Mapserver-users at l...
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
