[Mapserver-users] mapscript: new functions numMetaData and keyMetaData required
Sean Gillies
sgillies at frii.com
Mon Sep 22 11:29:43 EDT 2003
On Monday, September 22, 2003, at 09:08 AM, m.spring at gmx.de wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi Sean,
> your proposition is of course right. It's just that my c-knowledge is
> so minimal that I do not know how to write a true 'keys' function
> properly, this is why I came up with this barebones-c which would
> allow a hash-style wrapper to be added in the mapscript language of
> your choice (I do love coding in perl...)
> So please do go ahead, the way you describe is good and allows to keep
> more similar interfaces for the different scripting languages. I do
> not at all insist on the implementation, not even the interface I
> presented - it is in an such early stage that a redesign to achieve
> better functionality is most welcome.
> Kind regards
> Markus
Hi Markus,
Your code is good and I'm sure that many of us will be applying your
patch to use it. I will. MapScript needs (IMO) more active
developers, and I hope that you will want to continue to work on it.
If I create a new issue in the tracker to follow up on our discussion,
may I add you to the list of cc: addresses?
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://www.frii.com/~sgillies
