[Mapserver-users] help with annotations
Matt Doggett
mdoggett at coas.oregonstate.edu
Mon Sep 22 13:45:36 EDT 2003
This is a multi-part message in MIME format.
------=_NextPart_000_001E_01C380F6.A82282D0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
I have some point data where I want to display more than one data value =
in
the labels at each data point (eg. Temperature, windspeed, dewpt, etc). =
How
would I do this? I'm thinking that this would involve annotation layers =
but
I can't find any documentation that says exactly what they are or how to =
use
them. Can anyone shed some light on how to use annotation layers? I'm
using PHP/Mapscript if that helps.
TIA,
Matt
Matt Doggett
Spatial Climate Analysis Service
Oregon State University
316 Strand Ag Hall
Corvallis, OR 97331
(541)737-9153
=20
Content-Type: application/ms-tnef;
name="winmail.dat"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="winmail.dat"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------=_NextPart_000_001E_01C380F6.A82282D0--
