[Mapserver-users] question re Perl queryByShape
Lowell Filak
lfilak at medinaco.org
Mon Sep 22 14:07:28 EDT 2003
Please see below.
The following message was sent by Puneet Kishor
<pkishor at geoanalytics.com> on Mon, 22 Sep 2003 08:59:52 -0500.
> as I understand, here's the logic for querying by shape --
> 1. create a shape to query with (queryShpObj)
> my $queryShpObj = new blah blah;
> 2. call queryByShape on the map object (mapObj) using the above shape
> $mapObj->queryByShape($queryShpObj);
> Now, herein lies my question -- how does mapobject know which layer to
> query against? The intuitive model that I have learned (the Pavlovian
> Arcview way) is that you have first choose a layer before you can query
> against it. Even if we extend that model, we can make it plural...
> choose the layer or layers against which to query. So the syntax should
> be somewhat like
> my $queryLayerObj = new blah blah (proabably with a getLayerByName);
> $mapObj->queryByShape($queryShpObj, $queryLayerObj);
Isn't that what $layer->queryByShape is for?
Lowell
> Once that is done then one could(should) work with the $resultCacheObj
> my $resultCacheObj = $queryLayerObj->{resultcache};
> Not specifying the queryLayer(s) in step 2 above -- doesn't that make
> things slower?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
