[Mapserver-users] help with annotations
Dylan Keon
keon at nacse.org
Mon Sep 22 19:27:12 EDT 2003
Matt,
I'm not sure this is what you're after, but in one of my PHP apps I
label dynamically-created lines with text from user input. Assuming you
want to build your label text from database content, just run the query,
construct your several-item label ahead of time, and assign it to a
variable (or push the labels into an array). That variable would
replace "$label[$i]" in the code example below (which is part of a for
loop that adds the labels after I've rendered the lines):
$pt = ms_newLineObj();
$pt->addXY($x, $y);
$shape = ms_newShapeObj(MS_SHAPE_POINT);
$shape->set('classindex', 0);
$shape->set('text', $label[$i]); // assign the label
$shape->add($pt);
$layer = $map->getLayerByName('line_annotation');
$shape->draw($map, $layer, $image);
$pt->free();
$shape->free();
Here's the corresponding entry in my mapfile:
LAYER
NAME line_annotation
STATUS ON
TYPE ANNOTATION
FEATURE
END
CLASS
LABEL
TYPE TRUETYPE
FONT arial
SIZE 10
COLOR 0 0 0
POSITION UC
FORCE TRUE
END
END
END
--Dylan
Dylan Keon - GIS/Database Specialist
Northwest Alliance for Computational Science and Engineering
Oregon State University
Corvallis, OR 97331
keon at nacse.org voice: 541-737-6608 fax: 541-737-6609
Matt Doggett wrote:
> Someone else had suggested this same technique, and I've seen it in the
> documentation. But where do the values [FIRSTNAME] [LASTNAME] come from?
> My guess is that they are attribute 'columns' in the shape file. But
> here's the problem. My shape object is created dynamically with
> Php/Mapscript (from a query to a postgres database). I see that the
> ShapeObj class has the values array but apparently it is read-only so
> that I cannot dynamically create the data columns
> ([TEMP],[DEWPT],[WIND], etc) that this method would require. This
> problem is off topic but are there any suggestions?
> md
>>-----Original Message-----
>>From: mapserver-users-admin at lists.gis.umn.edu [mailto:mapserver-users-
>>admin at lists.gis.umn.edu] On Behalf Of Lowell Filak
>>Sent: Monday, September 22, 2003 1:04 PM
>>To: Matt Doggett; 'Tyler Mitchell'; mapserver-users at lists.gis.umn.edu
>>Subject: RE: [Mapserver-users] help with annotations
>>You can specify multiple 'text' attributes for the class, ie.
>>([FIRSTNAME],[LASTNAME]) .
>>Lowell
>>The following message was sent by "Matt Doggett"
>><mdoggett at coas.oregonstate.edu> on Mon, 22 Sep 2003 12:36:53 -0700.
>>>Well, I have a single point layer that contains weather station data.
> I
>>>currently have it so that the label (actually the 'text' attribute of
>>>the shape object) contains the station identifier. In addition to
> this,
>>>I also would like to be able to display one, some, all of additional
>>>data like temp, dewpt, winds, etc.
>>>None of the responses so far has suggested annotations so maybe
> that's
>>>not the direction I need to be going.
>>>matt
>>>>admin at lists.gis.umn.edu] On Behalf Of Tyler Mitchell
>>>>Sent: Monday, September 22, 2003 11:18 AM
>>>>To: mapserver-users at lists.gis.umn.edu
>>>>Subject: Re: [Mapserver-users] help with annotations
>>>>Do you just want to create labels that use more than one line (i.e.
>>>>multi-line labels) and use more than one attribute? Are you already
>>>>displaying labels okay? You can do all this using similar
> methodology
>>>as
>>>>far as I know. Maybe give us a short example of what you are
> already
>>>>doing and how you'd like that to change.
>>>>Tyler
>>>>mapserver-users-admin at lists.gis.umn.edu wrote on 09/22/2003 10:45:36
>>>AM:
>>>>>I have some point data where I want to display more than one data
>>>value
>>>>in
>>>>>the labels at each data point (eg. Temperature, windspeed, dewpt,
>>>etc).
>>>>How
>>>>>would I do this? I'm thinking that this would involve annotation
>>>layers
>>>>but
>>>>>I can't find any documentation that says exactly what they are or
> how
>>>to
>>>>use
>>>>>them. Can anyone shed some light on how to use annotation layers?
>>>I'm
>>>>>using PHP/Mapscript if that helps.
>>>>>TIA,
>>>>>Matt
>>>>>Matt Doggett
>>>>>Spatial Climate Analysis Service
>>>>>316 Strand Ag Hall
>>>>>Corvallis, OR 97331
>>>>>(541)737-9153
>>>>>[attachment "winmail.dat" deleted by Tyler Mitchell/Lignum]
>>>>_______________________________________________
>>>>Mapserver-users mailing list
>>>>Mapserver-users at lists.gis.umn.edu
>>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
