[Mapserver-users] Max image size
Ed McNierney
ed at topozone.com
Mon Sep 22 21:28:59 EDT 2003
Tyler -
By default, MapServer is usually built with a maximum image size of 1024 by
1024. This is to prevent your server from being abused when you're not
looking <g>. Many of us change it to a larger size, but you need to edit
map.h and recompile to do that. MapServer easily makes much larger output
files.
- Ed
Ed McNierney
TopoZone.com
> Is there a maximum image size that I can use. My app works fine with:
> SIZE 1024 768
> But not ...
> SIZE 2048 1024
> I should also say it's an RGB image.
> Without bombarding the list needlessly with my error messages, does anyone
> know off-hand whether or not MapServer, GD or GDAL has limitations in image
> size?
> (yes, I know that is quite large :)
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
