[Mapserver-users] File formats (MapInfo and DXF)
Michael Roach
burntmage at yahoo.com
Tue Sep 23 00:14:24 EDT 2003
--0-2023524445-1064290464=:24549
Content-Type: text/plain; charset=us-ascii
You can use the Mapinfo files directly in your layers. Assuming you have OGR compiled in. You really don't need shp files unless you are planning to upload the data to a PostGIS DB. I don't know of any Free program that will convert DXF to SHP. But, there is a library that will read and write DXF data at http://www.coin3d.org/Dime/about.php
LAYER NAME county TYPE POLYGON CONNECTIONTYPE OGR CONNECTION "/opt/mapdata/county.TAB" STATUS DEFAULT CLASS OUTLINECOLOR 100 100 100 COLOR 255 200 150 END #CLASS END #LAYER
LAYER NAME county_annot CONNECTIONTYPE OGR CONNECTION "/opt/mapdata/county.TAB" STATUS DEFAULT FORCE TRUE TYPE ANNOTATION LABELITEM "name" CLASS COLOR 100 100 100 LABEL MINDISTANCE 125 POSITION CC SIZE tiny COLOR 100 100 100 END #LABEL END #CLASS END #LAYER
Matthew Haines <mhaines94108 at hotmail.com> wrote:
I'm struggling with file formats. I've spent all day poking around in the
archives and
googling around. Here's my problem:
The New York City (Bytes of the Big Apple) map files come with the map part
in
what seems to be shapefile format. They unzip as .shp, .shx, .prj, and
.dbf. But the
street names seem to be in a .DXF file.
I have gotten things up and running using the shapefile and am happily
panning
and zooming across the outline map of the Manhattan streets. But I can't
figure out
how to convert the data in the .DXF file so I can display them. (I assume
I'll add
them as a layer.) I can also get that data in what seems to be MapInfo
files
(.TAB, .DAT, .ID, and .MAP).
Are there any free converters for these? It seems like back in 2000 there
were
several. But I've installed OGR and GeoExplorer, and they won't touch the
files.
Thanks,
Matthew Haines
http://www.nycPropertyResearch.com
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
Content-Type: text/html; charset=us-ascii
<DIV> You can use the Mapinfo files directly in your layers. Assuming you have OGR compiled in. You really don't need shp files unless you are planning to upload the data to a PostGIS DB. I don't know of any Free program that will convert DXF to SHP. But, there is a library that will read and write DXF data at <A href="http://www.coin3d.org/Dime/about.php">http://www.coin3d.org/Dime/about.php</A></DIV>
<DIV><PRE>LAYER
NAME county
TYPE POLYGON
CONNECTIONTYPE OGR
STATUS DEFAULT
CLASS
COLOR 255 200 150
END #CLASS
END #LAYER</PRE><PRE><!--StartFragment --><PRE>LAYER
NAME county_annot
CONNECTIONTYPE OGR
STATUS DEFAULT
FORCE TRUE
TYPE ANNOTATION
LABELITEM "name"
CLASS
COLOR 100 100 100
LABEL
MINDISTANCE 125
POSITION CC
SIZE tiny
COLOR 100 100 100
END #LABEL
END #CLASS
END #LAYER</PRE></PRE></DIV>
<DIV>-------------------------------------------------------------------------------------------------------------------------------<BR><BR><B><I>Matthew Haines <mhaines94108 at hotmail.com></I></B> wrote:</DIV>
<BLOCKQUOTE class=replbq style="PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #1010ff 2px solid">I'm struggling with file formats. I've spent all day poking around in the <BR>archives and<BR>googling around. Here's my problem:<BR><BR>The New York City (Bytes of the Big Apple) map files come with the map part <BR>in<BR>what seems to be shapefile format. They unzip as .shp, .shx, .prj, and <BR>.dbf. But the<BR>street names seem to be in a .DXF file.<BR><BR>I have gotten things up and running using the shapefile and am happily <BR>panning<BR>and zooming across the outline map of the Manhattan streets. But I can't <BR>figure out<BR>how to convert the data in the .DXF file so I can display them. (I assume <BR>I'll add<BR>them as a layer.) I can also get that data in what seems to be MapInfo <BR>files<BR>(.TAB, .DAT, .ID, and .MAP).<BR><BR>Are there any free converters for these? It seems like back in 2000 there <BR>were<BR>several. But I've installed OGR and GeoExplorer, and they
won't touch the <BR>files.<BR><BR>Thanks,<BR><BR>Matthew Haines<BR>http://www.nycPropertyResearch.com<BR><BR></BLOCKQUOTE><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://us.rd.yahoo.com/evt=10469/*http://sitebuilder.yahoo.com">Yahoo! SiteBuilder</a> - Free, easy-to-use web site design software
--0-2023524445-1064290464=:24549--
