[Mapserver-users] compile error 3.4
Swaminathan, Gayathri
gayathri at ou.edu
Tue Sep 23 09:18:46 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_000_01C381D5.37ED1F90
Content-Type: text/plain
Ah! Mika,
Looks like you are doing the same mistake that I did when I was trying to
compile mapserver 4.0
Version 4 build procedures have changed as follows:
1) There is a much leaner makefile.vc now.
2) All your library paths and include paths can be now set in nmake.opt that
comes with the mapserver download (like you do gdal)
So all you have to do is edit the nmake file to have your relative paths and
do nmake/f makefile.vc under your mapserver directory.
Attached with this email are my makefile and nmake files for your inference.
HTH,
Gayathri
-----Original Message-----
From: Mika Larronmaa [mailto:mika.larronmaa at gsf.fi]
Sent: Tuesday, September 23, 2003 12:22 AM
To: Swaminathan, Gayathri
Subject: RE: [Mapserver-users] compile error 3.4
Hi Gayathri,
Mistake the announcement will come even though I have commented on the
makefile.vc of the section in question out of the file. Along makefile.vc is
a file according to which I have tried to compile the programme.
# makefile.vc - Main MapServer makefile for MSVC++
# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the other #
MapServer command-line programs. # # To use the makefile: # - Open a DOS
prompt window # - Run the VCVARS32.BAT script to initialize the VC++
environment variables # - Start the build with: nmake /f makefile.vc # #
$Id: Makefile.vc,v 1.5 2001/01/09 05:29:00 dan Exp $ #
#OPTFLAGS = /nologo /Zi /W3 /DDEBUG
BASE_CFLAGS = $(OPTFLAGS)
# If you want to ignore missing datafile errors uncomment the following #
line. This is especially useful with large tiled datasets that may not #
have complete data for each tile. #
IGNORE_MISSING_DATA=-DIGNORE_MISSING_DATA
# Apparently these aren't as commonplace as I'd hoped. Edit the # following
line to reflect the missing functions on your platform. #
STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
# Freetype distribution (TrueType font support). Available at
http://www.freetype.org/. (RECOMMENDED) ##TTF_INC=-I../freetype/lib -I./gdft
##TTF_LIB=../freetype/lib/freetype.lib ./gdft/gdft.lib ##TTF=-DUSE_TTF
##TTF_GD=gdft
# Proj.4 distribution (cartographic projection routines). Not required for
normal use. (EXPERIMENTAL) ##PROJ_LIB=../proj/src/proj.lib
##PROJ_INC=-I../proj/src ##PROJ=-DUSE_PROJ
# GD distribution (graphics library GIF and/or PNG support). (REQUIRED) #
# - Version 1.2 is included and writes LZW GIF (-DUSE_GD_1_2).
# - Versions 1.3 to 1.5 write non-LZW GIF (-DUSE_GD_1_3).
# - Versions 1.6 and greater write PNG (-DUSE_GD_1_6). Add -lpng -lz to
GD_LIB line.
GDFONT_OBJ= gd-1.2/gdfontt.obj gd-1.2/gdfonts.obj gd-1.2/gdfontmb.obj \
gd-1.2/gdfontl.obj gd-1.2/gdfontg.obj
GD_INC= -I./gd-1.2
GD_LIB= gd-1.2/gd.lib
GD= -DUSE_GD_1_2
MAKE_GD=gd
# TIFF distribution (raster support for TIFF and GEOTIFF
imagery).(RECOMMENDED)
##TIFF_INC=-I../tiff-v3.5.4/libtiff
##TIFF_LIB=../tiff-v3.5.4/libtiff/libtiff.lib
##TIFF=-DUSE_TIFF
# JPEG distribution (raster support for grayscale JPEG images, INPUT ONLY).
#JPEG_INC= #JPEG_LIB=-ljpeg #JPEG=-DUSE_JPEG
# EPPL7 Support (this activates ERDAS as well) Included in the distribution.
Probably the best raster alternative if # you've got EPPL7 laying around.
See http://www.lmic.state.mn.us/ for more information. (RECOMMENDED)
##EPPL=-DUSE_EPPL ##EPPL_OBJ=epplib.obj
# OGR Support OGC Simple Feature inspired interface for vector # formats.
See http://gdal.velocet.ca/projects/opengis/
GDAL_DIR= ../gdal
##OGR=-DUSE_OGR
##OGR_LIB = $(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts.lib
$(GDAL_DIR)/ogr/ogrsf_frmts/ogrsf_frmts_sup.lib $(GDAL_DIR)/ogr/ogr.lib
$(GDAL_DIR)/ogr/../port/cpl.lib ##OGR_INC = -I$(GDAL_DIR)/ogr/ogrsf_frmts
-I$(GDAL_DIR)/ogr -I$(GDAL_DIR)/ogr/../port
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=-DUSE_EGIS
#ERR_OBJ=./errLog/errLog.o
#ERR_INC=-I./errLog
#ERR_LIB=-L./errLog -lerrLog
#IMGGEN_OBJ=./imgSrc/imgLib.o
#IMGGEN_INC=-I./imgSrc
#IMGGEN_LIB=-L./imgSrc -limgGEN
# VC++ does not include the REGEX library... so we must provide our one. #
The following definitions will try to build GNU regex-0.12 located in the #
regex-0.12 sub-directory. # If it was not included in the source
distribution, then you can get it
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
##REGEX_OBJ=.\regex-0.12\regex.obj
##REGEX_INC=-I./regex-0.12
# IMPORTANT NOTE ABOUT REGEX FOR PHP_MAPSCRIPT USERS:
# If you want to compile the PHP_MAPSCRIPT module, then you have to make #
MapServer uses the same version of the REGEX library that PHP was # compiled
with: # #PHP_REGEX=..\php-3.0.14\regex ##PHP_REGEX=..\php-4.0.4\regex
##REGEX_OBJ=$(PHP_REGEX)\regcomp.obj $(PHP_REGEX)\regerror.obj \
##$(PHP_REGEX)\regexec.obj $(PHP_REGEX)\regfree.obj
##REGEX_INC=-I$(PHP_REGEX) -DPHP_NO_ALIASES
# REGEX needs some special flags... here they are for VC++ 6.0 #
##REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
# --- You shouldn't have to edit anything else. ---
# Main MapServer library.
MS_LIB = mapserver.lib
MS_OBJS = mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
mapparser.obj maplexer.obj mapindex.obj maptree.obj \
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
maplegend.obj maputil.obj mapscale.obj mapquery.obj \
maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
mapraster.obj cgiutil.obj mapsde.obj mapogr.obj \
$(EPPL_OBJ) $(REGEX_OBJ)
MS_HDRS = map.h mapfile.h
MS_EXE = mapserv.exe shp2img.exe legend.exe shpindex.exe \
shptree.exe scalebar.exe sortshp.exe
LIBS = $(MS_LIB) $(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) $(TTF_LIB) \
$(PROJ_LIB) $(ERR_LIB) $(IMGGEN_LIB) $(OGR_LIB)
INCLUDES = $(GD_INC) $(TIFF_INC) $(JPEG_INC) $(TTF_INC) \
$(PROJ_INC) $(ERR_INC) $(IMGGEN_INC) $(REGEX_INC) $(OGR_INC)
CFLAGS = $(BASE_CFLAGS) $(INCLUDES) $(REGEX_OPT) $(STRINGS) \
$(EPPL) $(PROJ) $(TTF) $(TIFF) $(JPEG) $(GD) $(OGR)
default: all
all: $(MAKE_GD) $(TTF_GD) $(MS_LIB) $(MS_EXE)
$(MS_OBJS): $(MS_HDRS)
$(MS_LIB): $(MS_OBJS)
lib /out:$(MS_LIB) $(MS_OBJS)
$(MS_EXE): $(LIBS)
gd::
cd gd-1.2
nmake /f makefile.nt OPTFLAGS="$(OPTFLAGS)"
cd ..
gdft::
cd gdft
nmake /f makefile.vc OPTFLAGS="$(OPTFLAGS)"
cd ..
.c.obj:
$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
.cpp.obj:
$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
.c.exe:
$(CC) $*.obj $(LIBS)
.cpp.exe:
clean:
del *.obj
del $(REGEX_OBJ)
del $(MS_LIB)
del $(MS_EXE)
del *.pdb
del *.exp
del *.ilk
cd gd-1.2
nmake -f makefile.nt clean
cd ..
cd gdft
nmake -f makefile.vc clean
cd ..
From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
Sent: 22. syyskuuta 2003 16:30
To: 'Mika Larronmaa'; mapserver-users at lists.gis.umn.edu
Thanks,
Mika
Seems like regex related errors. Are you having the right path to regex in
your makefile.vc and are you having the regex.obj built before building
mapserver?
Thanks,
Gayathri
Sent: Monday, September 22, 2003 6:24 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] compile error 3.4
What's wrong? when i trying compile(windows xp pro) version 3.4 i get
following errors.
cd gd-1.2
nmake /f makefile.nt OPTFLAGS="/nologo /Zi"
cl gddemo.obj -o gddemo /link /LIBPATH:. gd.lib
Microsoft (R) Incremental Linker Version 6.00.8168
Copyright (C) Microsoft Corp 1992-1998. All rights reserved.
/out:gddemo.exe
/out:gddemo.exe
/LIBPATH:.
gd.lib
gddemo.obj
cl giftogd.obj -o giftogd /link /LIBPATH:. gd.lib
/out:giftogd.exe
/out:giftogd.exe
/LIBPATH:.
gd.lib
giftogd.obj
cl webgif.obj -o webgif /link /LIBPATH:. gd.lib
/out:webgif.exe
/out:webgif.exe
/LIBPATH:.
gd.lib
webgif.obj
cd ..
cl /nologo
/gd-1.2 -DNEED_STRCASECMP -DNEED_STRNCASECMP -DUSE_GD_1_2
/c mapserv.c /Fomapserv.obj
mapserv.c
cl mapserv.obj mapserver.lib gd-1.2/gd.lib
/out:mapserv.exe
mapserv.obj
mapserver.lib
gd-1.2/gd.lib
mapserv.obj: error LNK2001: unresolved external symbol _regfree
mapserver.lib(mapfile.obj): error LNK2001: unresolved external symbol
_regfree
mapserver.lib(mapquery.obj): error LNK2001: unresolved external symbol
_regfree
mapserver.lib(mapparser.obj): error LNK2001: unresolved external symbol
_regfree mapserv.obj : error LNK2001: unresolved external symbol
_strncasecmp mapserv.obj : error LNK2001: unresolved external symbol
_regcomp
_regcomp
_regcomp
_regcomp mapserv.obj : error LNK2001: unresolved external symbol _strcasecmp
_strcasecmp
mapserver.lib(maputil.obj): error LNK2001: unresolved external symbol
_strcasecmp
_regexec mapserv.obj : error LNK2001: unresolved external symbol _regexec
_regexec
_regexec
_regexec mapserv.exe : fatal error LNK1120: 5 unresolved externals
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/octet-stream;
name="make.zip"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="make.zip"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------_=_NextPart_000_01C381D5.37ED1F90--
