[Mapserver-users] MUM Presentation / MapClient
Jan Hartmann
jhart at frw.uva.nl
Tue Sep 23 10:43:56 EDT 2003
I have never used HTML legends, but I see several ways of using them
with MapClient.The first two are simple, the third one is more complex,
and the fourth one is very flexible, but will require quite a bit of
figuring.
1) In a simple windowed application, the main template file returned by
MapServer is put inside the window. There is no essential difference
between a windowed application and a normal MapServer application; in a
regular application, all MapServer results will be put in a new page or
a separate frame, while in a windowed application everything will be put
within the window. This means that you can use the [legend] tag in the
main template file just as usual.
2) You can request the legend only in a separate call to MapServer by
setting MODE=LEGEND. In that case MapServer will return a raw image. If
you use serverFrames, you can put this image wherever you want in the
browser (see User Guide 4.2, and the serverframe2.html example). The
code for this would be something like:
s1 = new serverFrame()
s1.setServerURL,"your_MapServer_CGI")
s1.setVar("map","your_mapfile")
s1.setVar("mode","legend")
s1.setTarget("some image in your page")
s1.submit()
On return, the legend image will be put in the specified browser image.
3) In normal mode (MODE=MAP), MapServer will return raw HTML code when
the LEGEND TEMPLATE is set . This code will replace the [legend] tag in
the main template file. If the main template file has only this [legend]
tag, the returned page will be the complete HTML code for the HTML
legend. Code to retrieve this would look like:
s2 = new serverFrame()
s1.setServerURL,"...")
s1.seVar("map","...")
s1.setTarget(s2)
s2.setExecOnReturn("funtion to process the returned HTML legend")
s1.submit()
On return, s2 will be filled with the HTML legend. This has to be copied
to visible screen locations by an onReturn function. For this, you need
to access the HTML code in s2 via the DOM interface, in other words to
find out how the different elements are named. The complete
serverFrame's HTML code can be reached as follows:
s2.contentWindow.document.body.innerHTML
You can copy this block to every element in the main HTML page. I use
empty SPAN and DIV elements for this. If the main page looks like this:
<body>
<span id=legendSpan></span>
</body>
you can copy the legend from the serverFrame onto the page by:
var sp = document.getElementById("legendSpan")
var lg = s2.contentWindow.document.body
sp.innerHTML = lg.innerHTML
4) Alternatively, you can even access the individual elements of the
returned legend HTML. I don't know exactly how this HTML is built up,
but it looks as if the elements are ordered as tables. The first table
can be accessed as:
var table1 = s2.contentWindow.document.getELementsByTagName("table")[0]
The individual elements of this table can be accessed from this table1
variable. This gives great flexibility: you can put every single legend
item wherever you want, but it will take some figuring how every element
is named.
mvg,
Jan
> Hi!
> I'm just testing the MapClient and I think it is great.
> My question:
> Is there a simple way to use HTML legends with MapClient.
> Mvh
> Lars-Göran Edholm tel 026/24 14 36
> 1:e byggnadsinspektör
> Bygg- och miljökontoret
> 811 80 Sandviken
> lars-goran.edholm at sandviken.se
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
