[Mapserver-users] Focus immediately on a map feature
Eduardo Spremolla
edspremolla at Antel.com.uy
Wed Sep 24 08:04:32 EDT 2003
What you need to use is a itemquery . look at this form:
<form method="GET" id="qrbs" action="/cgi-bin/mapserv" >
<input type="hidden" name="map" id="map" value="[map]">
<input type="hidden" id="ext" name="imgext" value="[mapext]">
<input type="hidden" name="imgxy" value="[center]">
<input type="hidden" name="mode" value="itemnquery">
<input type="hidden" name="qlayer" value="rbs">
<input type="hidden" name="map_rbs_filteritem" value="NOMBRE">
Busqueda por radiobase <input type="text" id="rbs_name"
name="map_rbs_filter" value="">
<input type="submit" name="Buscar" onClick="reparo2();">
</form>
here I search the rbs layer for a given name and got this template
filled:
<tr><td>[NOMBRE]</td><td>[nombdepto]</td></td>
<td><a
href="/cgi-bin/mapserv?map=[map]&imgext=[mapext]&imgxy=[center]&zoomdir=0&zoomsize=2&submit=Redibujar&mode=browse" >Browse</a></td></tr>
<tr><td colspan="6"><img border="2" src="[img]" height="300"
width="300"></td> </tr>
the second row in the table is what you wont: the feature zoomed map
LALO
El mar, 23 de 09 de 2003 a las 20:53, Matthew Haines escribió:
> Thanks to some helpful pointers I've gotten my map server up and running and
> can now display a street map of Manhattan along with the street names.
> Can someone point me in the right direction? Now I want to spit out static
> (ie, no pan and zoom) maps centered on a particular feature and zoomed to a
> hardcoded level. Ideally I would like to do this using the CGI access to
> mapserver, that is by encoding all of the parameters in the URL and the .map
> file.
> Is it possible to do this from a static .map file and a URL generated on the
> fly? Or do I need to explore some of the scripting options for mapserver?
> A pointer to some samples would be very helpful.
> Here's a little more thorough explanation of what I want to do:
> I have a map file (Bytes of the Big Apple) that consists of the tax blocks
> for Manhattan (New York). When I query the file with OGR I get something
> like
> OGRFeature(mn_tb):1403
> TAXBLOCK(Real) = 1186
> Style = [etc]
> POLYGON (( ... etc ...))
> Instead of displaying the full extent of the map, I want to center the map
> over a particular TAXBLOCK and display maybe 1/2 mile radius. Ideally I'd
> have a URL that would have the TAXBLOCK variable in it and a non-changing
> .map file.
> Matthew
> _________________________________________________________________
> High-speed Internet access as low as $29.95/month (depending on the local
> service providers in your area). Click here. https://broadband.msn.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
