[Mapserver-users] broken link on website and java questions
Umberto Nicoletti
unicoletti at prometeo.it
Thu Sep 25 03:29:38 EDT 2003
--=-U2ATVM1FhqTif5SyaFGp
Content-Type: text/plain
Content-Transfer-Encoding: 7bit
hi,
just wanted to let the webmaster know that there is a broken link on
website.
If you go to:
http://mapserver.gis.umn.edu/doc40/phpmapscript-byexample-howto.html
and then try to download the examples files you get a 404.
Then I have another question: I am evaluating mapserver java mapscript
extension and I am getting frequent core dump from java vm.
I am using redhat 9 linux, jdk 1.4.2, tomcat 4.1.27, mapserver 4.0 ,
java mapscript generated with swig SWIG-1.3.19.
Attached there is a core dump file.
I am using both the map from mapserver source (the one with different
types of lines) and maps from itasca.
Please bear with me as I am not map/gis guru, even though I am an
experienced java web developer.
Thanks,
umberto
Content-Disposition: attachment; filename=hs_err_pid4707.log
Content-Type: text/plain; name=hs_err_pid4707.log; charset=iso-8859-15
An unexpected exception has been detected in native code outside the VM.
Unexpected Signal : 11 occurred at PC=0x4ECD17D0
Function=msDrawMap+0xC
Library=/opt/grass-libs/lib/libmapscript.so
Current Java thread:
at edu.umn.gis.mapscript.mapscriptJNI.mapObj_draw(Native Method)
at edu.umn.gis.mapscript.mapObj.draw(mapObj.java:340)
at it.prometeo.cartografia.MapRenderer.render(MapRenderer.java:14)
at it.prometeo.cartografia.MapRendererBridge.render(MapRendererBridge.java:10)
at org.apache.jsp.index_jsp._jspService(index_jsp.java:57)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:137)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:853)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:210)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:295)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:241)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:247)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:256)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:643)
at org.apache.catalina.core.StandardPipeline.invoke(StandardPipeline.java:480)
at org.apache.catalina.core.ContainerBase.invoke(ContainerBase.java:995)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardContext.invoke(StandardContext.java:2416)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:180)
at org.apache.catalina.valves.ErrorDispatcherValve.invoke(ErrorDispatcherValve.java:171)
at org.apache.catalina.core.StandardPipeline$StandardPipelineValveContext.invokeNext(StandardPipeline.java:641)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:172)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:174)
at org.apache.coyote.tomcat4.CoyoteAdapter.service(CoyoteAdapter.java:223)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:601)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.processConnection(Http11Protocol.java:392)
at org.apache.tomcat.util.net.TcpWorkerThread.runIt(PoolTcpEndpoint.java:565)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:619)
at java.lang.Thread.run(Thread.java:534)
Dynamic libraries:
08048000-0804e000 r-xp 00000000 03:45 493 /usr/java/j2sdk1.4.2_01/bin/java
0804e000-0804f000 rw-p 00005000 03:45 493 /usr/java/j2sdk1.4.2_01/bin/java
40000000-40015000 r-xp 00000000 03:45 224094 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00014000 03:45 224094 /lib/ld-2.3.2.so
40017000-4001f000 r-xp 00000000 03:45 83165 /usr/java/j2sdk1.4.2_01/jre/lib/i386/native_threads/libhpi.so
4001f000-40020000 rw-p 00007000 03:45 83165 /usr/java/j2sdk1.4.2_01/jre/lib/i386/native_threads/libhpi.so
40020000-40024000 rw-s 00000000 03:45 51180 /tmp/hsperfdata_root/4707
40024000-40027000 r--s 00000000 03:45 99157 /usr/java/j2sdk1.4.2_01/jre/lib/ext/dnsns.jar
40027000-4002a000 r--s 00000000 03:46 432020 /opt/jakarta-tomcat-4.1.27/bin/commons-daemon.jar
4002a000-40034000 r-xp 00000000 03:45 64108 /lib/tls/libpthread-0.29.so
40034000-40035000 rw-p 0000a000 03:45 64108 /lib/tls/libpthread-0.29.so
40037000-40039000 r-xp 00000000 03:45 224105 /lib/libdl-2.3.2.so
40039000-4003a000 rw-p 00002000 03:45 224105 /lib/libdl-2.3.2.so
4003b000-40435000 r-xp 00000000 03:45 275116 /usr/java/j2sdk1.4.2_01/jre/lib/i386/client/libjvm.so
40435000-40451000 rw-p 003f9000 03:45 275116 /usr/java/j2sdk1.4.2_01/jre/lib/i386/client/libjvm.so
40463000-40475000 r-xp 00000000 03:45 224109 /lib/libnsl-2.3.2.so
40475000-40476000 rw-p 00011000 03:45 224109 /lib/libnsl-2.3.2.so
40478000-40499000 r-xp 00000000 03:45 64106 /lib/tls/libm-2.3.2.so
40499000-4049a000 rw-p 00020000 03:45 64106 /lib/tls/libm-2.3.2.so
4049a000-404aa000 r-xp 00000000 03:45 419189 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libverify.so
404aa000-404ac000 rw-p 0000f000 03:45 419189 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libverify.so
404ad000-404b8000 r-xp 00000000 03:45 224115 /lib/libnss_files-2.3.2.so
404b8000-404b9000 rw-p 0000a000 03:45 224115 /lib/libnss_files-2.3.2.so
404b9000-404d9000 r-xp 00000000 03:45 419175 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libjava.so
404d9000-404db000 rw-p 0001f000 03:45 419175 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libjava.so
404db000-404ef000 r-xp 00000000 03:45 419190 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libzip.so
404ef000-404f2000 rw-p 00013000 03:45 419190 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libzip.so
404f2000-40511000 r--s 00000000 03:46 400004 /opt/jakarta-tomcat-4.1.27/common/endorsed/xmlParserAPIs.jar
40511000-405ec000 r--s 00000000 03:46 400005 /opt/jakarta-tomcat-4.1.27/common/endorsed/xercesImpl.jar
405ec000-41f84000 r--s 00000000 03:45 1269 /usr/java/j2sdk1.4.2_01/jre/lib/rt.jar
41fce000-41fe4000 r--s 00000000 03:45 1268 /usr/java/j2sdk1.4.2_01/jre/lib/sunrsasign.jar
41fe4000-41ff5000 r--s 00000000 03:45 1259 /usr/java/j2sdk1.4.2_01/jre/lib/jce.jar
41ff5000-41ffb000 r--s 00000000 03:46 432011 /opt/jakarta-tomcat-4.1.27/bin/bootstrap.jar
41ffb000-41ffd000 r--s 00000000 03:46 112016 /opt/jakarta-tomcat-4.1.27/common/lib/jdbc2_0-stdext.jar
41ffd000-42000000 r--s 00000000 03:46 112020 /opt/jakarta-tomcat-4.1.27/common/lib/jta.jar
42000000-4212e000 r-xp 00000000 03:45 64104 /lib/tls/libc-2.3.2.so
4212e000-42131000 rw-p 0012e000 03:45 64104 /lib/tls/libc-2.3.2.so
42133000-4220e000 r--s 00000000 03:45 1267 /usr/java/j2sdk1.4.2_01/jre/lib/jsse.jar
4220e000-42767000 r--s 00000000 03:45 1260 /usr/java/j2sdk1.4.2_01/jre/lib/charsets.jar
4ca10000-4cc10000 r--p 00000000 03:45 448126 /usr/lib/locale/locale-archive
4ce10000-4ce1d000 r--s 00000000 03:45 99158 /usr/java/j2sdk1.4.2_01/jre/lib/ext/ldapsec.jar
4ce1d000-4ced9000 r--s 00000000 03:45 99202 /usr/java/j2sdk1.4.2_01/jre/lib/ext/localedata.jar
4ced9000-4cef5000 r--s 00000000 03:45 99160 /usr/java/j2sdk1.4.2_01/jre/lib/ext/sunjce_provider.jar
4cef5000-4d3d1000 r--s 00000000 03:45 66402 /usr/java/j2sdk1.4.2_01/lib/tools.jar
4d3d1000-4d3dd000 r--s 00000000 03:46 112005 /opt/jakarta-tomcat-4.1.27/common/lib/activation.jar
4d3dd000-4d3ef000 r--s 00000000 03:46 112006 /opt/jakarta-tomcat-4.1.27/common/lib/jasper-runtime.jar
4d3ef000-4d41c000 r--s 00000000 03:46 112007 /opt/jakarta-tomcat-4.1.27/common/lib/jasper-compiler.jar
4d41c000-4d426000 r--s 00000000 03:46 112008 /opt/jakarta-tomcat-4.1.27/common/lib/naming-resources.jar
4d426000-4d44f000 r--s 00000000 03:46 112009 /opt/jakarta-tomcat-4.1.27/common/lib/commons-collections.jar
4d44f000-4d456000 r--s 00000000 03:46 112010 /opt/jakarta-tomcat-4.1.27/common/lib/naming-common.jar
4d456000-4d45c000 r--s 00000000 03:46 112011 /opt/jakarta-tomcat-4.1.27/common/lib/commons-logging-api.jar
4d45c000-4d511000 r--s 00000000 03:46 112012 /opt/jakarta-tomcat-4.1.27/common/lib/ant.jar
4d511000-4d556000 r--s 00000000 03:46 112013 /opt/jakarta-tomcat-4.1.27/common/lib/mail.jar
4d556000-4d566000 r--s 00000000 03:46 112014 /opt/jakarta-tomcat-4.1.27/common/lib/commons-dbcp.jar
4d566000-4d57a000 r--s 00000000 03:46 112015 /opt/jakarta-tomcat-4.1.27/common/lib/servlet.jar
4d57a000-4d582000 r--s 00000000 03:46 112017 /opt/jakarta-tomcat-4.1.27/common/lib/commons-pool.jar
4d582000-4d59b000 r--s 00000000 03:46 112018 /opt/jakarta-tomcat-4.1.27/common/lib/jndi.jar
4d59b000-4d5a0000 r--s 00000000 03:46 112019 /opt/jakarta-tomcat-4.1.27/common/lib/naming-factory.jar
4d5a0000-4d5a5000 r--s 00000000 03:46 64028 /opt/jakarta-tomcat-4.1.27/server/lib/servlets-manager.jar
4d5a5000-4d65d000 r--s 00000000 03:46 64029 /opt/jakarta-tomcat-4.1.27/server/lib/catalina.jar
4d65d000-4d678000 r--s 00000000 03:46 64030 /opt/jakarta-tomcat-4.1.27/server/lib/commons-digester.jar
4d678000-4d682000 r--s 00000000 03:46 64031 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-http11.jar
4d682000-4d68a000 r--s 00000000 03:46 64032 /opt/jakarta-tomcat-4.1.27/server/lib/commons-logging.jar
4d68a000-4d690000 r--s 00000000 03:46 64033 /opt/jakarta-tomcat-4.1.27/server/lib/commons-fileupload-1.0.jar
4d690000-4d692000 r--s 00000000 03:46 64034 /opt/jakarta-tomcat-4.1.27/server/lib/servlets-invoker.jar
4d692000-4d698000 r--s 00000000 03:46 64035 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-warp.jar
4d698000-4d6a8000 r--s 00000000 03:46 64036 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-coyote.jar
4d6a8000-4d6d1000 r--s 00000000 03:46 64037 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-util.jar
4d6d1000-4d6d3000 r--s 00000000 03:46 64038 /opt/jakarta-tomcat-4.1.27/server/lib/servlets-common.jar
4d6d3000-4d727000 r--s 00000000 03:46 64039 /opt/jakarta-tomcat-4.1.27/server/lib/mx4j-jmx.jar
4d727000-4d72d000 r--s 00000000 03:46 64040 /opt/jakarta-tomcat-4.1.27/server/lib/servlets-webdav.jar
4d72d000-4d747000 r--s 00000000 03:46 64041 /opt/jakarta-tomcat-4.1.27/server/lib/jaas.jar
4d747000-4d764000 r--s 00000000 03:46 64042 /opt/jakarta-tomcat-4.1.27/server/lib/commons-beanutils.jar
4d764000-4d778000 r--s 00000000 03:46 64043 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-jk2.jar
4d778000-4d788000 r--s 00000000 03:46 64047 /opt/jakarta-tomcat-4.1.27/server/lib/tomcat-jk.jar
4d788000-4d78c000 r--s 00000000 03:46 64048 /opt/jakarta-tomcat-4.1.27/server/lib/catalina-ant.jar
4d78c000-4d791000 r--s 00000000 03:46 64049 /opt/jakarta-tomcat-4.1.27/server/lib/servlets-default.jar
4d791000-4d799000 r--s 00000000 03:46 64050 /opt/jakarta-tomcat-4.1.27/server/lib/commons-modeler.jar
4d799000-4d7a1000 r--s 00000000 03:46 64051 /opt/jakarta-tomcat-4.1.27/server/lib/jakarta-regexp-1.2.jar
4d7a1000-4d7b1000 r-xp 00000000 03:45 419186 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libnet.so
4d7b1000-4d7b2000 rw-p 0000f000 03:45 419186 /usr/java/j2sdk1.4.2_01/jre/lib/i386/libnet.so
4d8b2000-4da8a000 r--s 00000000 03:46 320199 /opt/jakarta-tomcat-4.1.27/webapps/VIA/WEB-INF/lib/classes12.jar
4da8a000-4da92000 r--s 00000000 03:46 320202 /opt/jakarta-tomcat-4.1.27/webapps/VIA/WEB-INF/lib/commons-logging.jar
4da92000-4dae8000 r--s 00000000 03:46 320201 /opt/jakarta-tomcat-4.1.27/webapps/VIA/WEB-INF/lib/log4j-1.2.7.jar
4dae8000-4db02000 r--s 00000000 03:46 320200 /opt/jakarta-tomcat-4.1.27/webapps/VIA/WEB-INF/lib/oreilly.jar
4db82000-4dbfc000 r--s 00000000 03:46 16106 /opt/jakarta-tomcat-4.1.27/server/webapps/admin/WEB-INF/lib/struts.jar
4dbfc000-4dc50000 r--s 00000000 03:46 512213 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/JTS-1.0.jar
4dc50000-4dc5b000 r--s 00000000 03:46 512206 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/core-0.1.jar
4dc5b000-4dc71000 r--s 00000000 03:46 512208 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/defaultcore-0.1.jar
4dc71000-4dc74000 r--s 00000000 03:46 512211 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/imagedatasource-0.1.jar
4dc74000-4dc76000 r--s 00000000 03:46 512214 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/littleEndian-1.0.jar
4dcf6000-4dd70000 r--s 00000000 03:46 16106 /opt/jakarta-tomcat-4.1.27/server/webapps/admin/WEB-INF/lib/struts.jar
4dd70000-4ddb3000 r--s 00000000 03:46 512207 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/cts-coordtrans-0.6.jar
4ddb3000-4ddc0000 r--s 00000000 03:46 512209 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/filter-0.1.jar
4ddc0000-4ddc7000 r--s 00000000 03:46 512212 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/java2drendering-0.1.jar
4ddc7000-4ddcb000 r--s 00000000 03:46 512215 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/postgis-0.1.jar
4ddcb000-4ddce000 r--s 00000000 03:46 512216 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/postgis-driver-1.0.jar
4ddce000-4ddd2000 r--s 00000000 03:46 512220 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/sldstyling-0.1.jar
4ded2000-4df07000 r--s 00000000 03:46 512210 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/gcs-coverage-0.6.jar
4df07000-4df1d000 r--s 00000000 03:46 512217 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/postgresql-1.0.jar
4df1d000-4df40000 r--s 00000000 03:46 512218 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/resources-0.1.jar
4df40000-4df4c000 r--s 00000000 03:46 512219 /opt/jakarta-tomcat-4.1.27/webapps/wmsserver/WEB-INF/lib/shapefile-0.1.jar
4dfcc000-4dfe9000 r--s 00000000 03:46 608197 /opt/jakarta-tomcat-4.1.27/webapps/cartografia/WEB-INF/lib/mapscript.jar
4dfe9000-4e006000 r--s 00000000 03:46 16155 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-beanutils.jar
4e209000-4e3e1000 r--s 00000000 03:46 16164 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/classes12.jar
4e3e1000-4e40a000 r--s 00000000 03:46 16156 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-collections.jar
4e40a000-4e41f000 r--s 00000000 03:46 16168 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-dbcp.jar
4e41f000-4e43a000 r--s 00000000 03:46 16157 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-digester.jar
4e43a000-4e440000 r--s 00000000 03:46 16158 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-fileupload.jar
4e440000-4e450000 r--s 00000000 03:46 16159 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-lang.jar
4e450000-4e458000 r--s 00000000 03:46 16160 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-logging.jar
4e458000-4e462000 r--s 00000000 03:46 16169 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-pool.jar
4e462000-4e46b000 r--s 00000000 03:46 16170 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-resources.jar
4e46b000-4e47f000 r--s 00000000 03:46 16173 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-scaffold.jar
4e47f000-4e485000 r--s 00000000 03:46 16171 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-services.jar
4e485000-4e491000 r--s 00000000 03:46 16161 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/commons-validator.jar
4e491000-4e53f000 r--s 00000000 03:46 16172 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/hibernate2.jar
4e53f000-4e54f000 r--s 00000000 03:46 16162 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/jakarta-oro.jar
4e54f000-4e56d000 r--s 00000000 03:46 16165 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/junit.jar
4e56d000-4e5c3000 r--s 00000000 03:46 16167 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/log4j-1.2.7.jar
4e5c3000-4e5c9000 r--s 00000000 03:46 16174 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/securityfilter.jar
4e5c9000-4e5d3000 r--s 00000000 03:46 16176 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/sicurezza-10-September-2003.jar
4e5d3000-4e5d9000 r--s 00000000 03:46 16166 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/struts-scaffold.jar
4e5d9000-4e653000 r--s 00000000 03:46 16163 /opt/jakarta-tomcat-4.1.27/webapps/rifiuti2/WEB-INF/lib/struts.jar
4e753000-4e75a000 r-xp 00000000 03:45 224198 /lib/libgcc_s-3.2.2-20030225.so.1
4e75a000-4e75b000 rw-p 00007000 03:45 224198 /lib/libgcc_s-3.2.2-20030225.so.1
4ec5e000-4ecf8000 r-xp 00000000 03:46 288218 /opt/grass-libs/lib/libmapscript.so
4ecf8000-4ecfd000 rw-p 00099000 03:46 288218 /opt/grass-libs/lib/libmapscript.so
4ecfd000-4ed10000 r-xp 00000000 03:46 288160 /opt/grass-libs/lib/libgd.so.2.0.0
4ed10000-4ed2f000 rw-p 00013000 03:46 288160 /opt/grass-libs/lib/libgd.so.2.0.0
4ed33000-4ed39000 r--s 00000000 03:45 208263 /usr/lib/gconv/gconv-modules.cache
4ed46000-4ed63000 r-xp 00000000 03:45 336204 /usr/lib/libjpeg.so.62.0.0
4ed63000-4ed64000 rw-p 0001d000 03:45 336204 /usr/lib/libjpeg.so.62.0.0
4ed64000-4ed89000 r-xp 00000000 03:45 336200 /usr/lib/libttf.so.2.3.0
4ed89000-4ed8a000 rw-p 00024000 03:45 336200 /usr/lib/libttf.so.2.3.0
4ed8a000-4edac000 r-xp 00000000 03:45 336208 /usr/lib/libpng12.so.0.1.2.2
4edac000-4edad000 rw-p 00022000 03:45 336208 /usr/lib/libpng12.so.0.1.2.2
4edad000-4edb9000 r-xp 00000000 03:45 336118 /usr/lib/libz.so.1.1.4
4edb9000-4edbb000 rw-p 0000b000 03:45 336118 /usr/lib/libz.so.1.1.4
4edbb000-4edfa000 r-xp 00000000 03:45 336209 /usr/lib/libtiff.so.3.5
4edfa000-4edfc000 rw-p 0003f000 03:45 336209 /usr/lib/libtiff.so.3.5
4edfc000-4eea5000 r-xp 00000000 03:45 336156 /usr/lib/libstdc++.so.5.0.3
4eea5000-4eeaa000 rw-p 000a9000 03:45 336156 /usr/lib/libstdc++.so.5.0.3
4eeaf000-4eebd000 r-xp 00000000 03:45 64429 /usr/X11R6/lib/libXpm.so.4.11
4eebd000-4eebe000 rw-p 0000d000 03:45 64429 /usr/X11R6/lib/libXpm.so.4.11
4eebe000-4ef9a000 r-xp 00000000 03:45 64403 /usr/X11R6/lib/libX11.so.6.2
4ef9a000-4ef9d000 rw-p 000db000 03:45 64403 /usr/X11R6/lib/libX11.so.6.2
4ef9d000-4efe9000 r-xp 00000000 03:45 336198 /usr/lib/libfreetype.so.6.3.2
4efe9000-4efed000 rw-p 0004c000 03:45 336198 /usr/lib/libfreetype.so.6.3.2
Heap at VM Abort:
Heap
def new generation total 896K, used 770K [0x44810000, 0x44900000, 0x44cf0000)
eden space 832K, 88% used [0x44810000, 0x448c71b8, 0x448e0000)
from space 64K, 59% used [0x448f0000, 0x448f9820, 0x44900000)
to space 64K, 0% used [0x448e0000, 0x448e0000, 0x448f0000)
tenured generation total 10772K, used 7547K [0x44cf0000, 0x45775000, 0x48810000)
the space 10772K, 70% used [0x44cf0000, 0x4544efe8, 0x4544f000, 0x45775000)
compacting perm gen total 8192K, used 7971K [0x48810000, 0x49010000, 0x4c810000)
the space 8192K, 97% used [0x48810000, 0x48fd8c98, 0x48fd8e00, 0x49010000)
Local Time = Wed Sep 24 12:49:31 2003
Elapsed Time = 22
# The exception above was detected in native code outside the VM
# Java VM: Java HotSpot(TM) Client VM (1.4.2_01-b06 mixed mode)
--=-U2ATVM1FhqTif5SyaFGp--
