[Mapserver-users] mapserver4/tiff/win2K - linux
Swaminathan, Gayathri
gayathri at ou.edu
Thu Sep 25 09:51:34 EDT 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3836C.22190EC0
Content-Type: text/plain
Hi:
The explanation on both as from the mapserver site below:
* <https://freemail.web.de/win32bin/ms40_gif_pg.zip> ms40_gif_pg.zip:
Output support includes GIF, PDF, SWF, and all output formats supported by
GDAL and GD; input support includes many OGR supported vector formats, GDAL
raster files, PostGIS geospatial databases; also includes truetype fonts and
on-the-fly projection support.
* <https://freemail.web.de/win32bin/ms40_png_pg.zip> ms40_png_pg.zip:
Output support includes PDF, SWF, and all output formats supported by GDAL
and GD (no GIF support); input support includes many OGR supported vector
formats, GDAL raster files, PostGIS geospatial databases; also includes
truetype fonts and on-the-fly projection support.
I do not see input type tiff enabled. This is not a problem with GDAL.
I think you are going to have to compile yourself with TIFF enabled.
Would you want to compile this yourself? It has become fairly easy to do
this in mapserver 4.
I do have a mapserv with input tiff enabled if you want to try...
Let me know if you need help or anything else.
Thanks,
Gayathri
-----Original Message-----
Sent: Thursday, September 25, 2003 8:20 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] mapserver4/tiff/win2K - linux
Hello,
I updated the mapserver from ms36 to ms40 (Win2000) and *some* tiffs are not
shown anymore. I use tiffs with 256 colors. Now, the grayscale tiffs are v!
isible, the colormapped are not. If the grayscale tiffs are visible, the
color of the shape-polygons are not as set in the map file!
Using ms4 and linux, all tiffs are shown without any problems.
Maybe there is a problem with a GDAL/GD in the windows version of mapserver
4? I tried the <http://mapserver.gis.umn.edu/win32bin/ms40_png_pg.zip>
ms40_png_pg.zip and mapserver-4.0-win32-php4.3.2.zip.
Thank you,
Robert
____________________________________________________________________________
__
Zwei Mal Platz 1 mit dem jeweils besten Testergebnis! WEB.DE FreeMail
und WEB.DE Club bei Stiftung Warentest! <http://f.web.de/?mc=021183>
http://f.web.de/?mc=021183 _______________________________________________
Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: text/html
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML xmlns:o =
"urn:schemas-microsoft-com:office:office"><HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; charset=us-ascii">
<TITLE>Message</TITLE>
<BASE
href=https://freemail.web.de/>
<STYLE>p {margin: 0px}</STYLE>
<META content="MSHTML 6.00.2800.1226" name=GENERATOR></HEAD>
<BODY style="FONT-SIZE: 9pt; FONT-FAMILY: Verdana">
<DIV><SPAN class=390575713-25092003><FONT size=2>Hi:</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2></FONT></SPAN> </DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>The explanation on both as from
the mapserver site below:</FONT></SPAN></DIV>
<LI><A href="https://freemail.web.de/win32bin/ms40_gif_pg.zip"><FONT
size=2>ms40_gif_pg.zip</FONT></A><FONT size=2>: Output support includes GIF,
PDF, SWF, and all output formats supported by GDAL and GD; input support
includes many OGR supported vector formats, GDAL raster files, PostGIS
geospatial databases; also includes truetype fonts and on-the-fly projection
support.<BR></FONT>
<LI><A href="https://freemail.web.de/win32bin/ms40_png_pg.zip"><FONT
size=2>ms40_png_pg.zip</FONT></A><FONT size=2>: Output support includes PDF,
SWF, and all output formats supported by GDAL and GD (no GIF support); input
support includes many OGR supported vector formats, GDAL raster files, PostGIS
support.</FONT></LI></DIV>
<DIV><FONT size=2></FONT> </DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>I do not see input type tiff
enabled. This is not a problem with GDAL.</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>I think you are going to have
to compile yourself with TIFF enabled.</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>Would you want to compile this
yourself? It has become fairly easy to do this in mapserver 4.
<DIV><SPAN class=390575713-25092003><FONT size=2>I do have a mapserv with input
tiff enabled if you want to try...</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003></SPAN><SPAN class=390575713-25092003><FONT
<DIV><SPAN class=390575713-25092003><FONT size=2>Let me know if you need help or
anything else.</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>Thanks,</FONT></SPAN></DIV>
<DIV><SPAN class=390575713-25092003><FONT size=2>Gayathri</FONT></SPAN></DIV>
<DIV></SPAN> </DIV>
<BLOCKQUOTE style="MARGIN-RIGHT: 0px">
<DIV></DIV>
<DIV class=OutlookMessageHeader lang=en-us dir=ltr align=left><FONT
face=Tahoma size=2>-----Original Message-----<BR><B>From:</B> robert fritz
[mailto:robert-fritz at web.de] <BR><B>Sent:</B> Thursday, September 25, 2003
8:20 AM<BR><B>To:</B> mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B>
[Mapserver-users] mapserver4/tiff/win2K - linux<BR><BR></FONT></DIV>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN-GB
style="mso-ansi-language: EN-GB"><FONT size=3><FONT
face="Times New Roman">Hello,<o:p></o:p></FONT></FONT></SPAN></P>
face="Times New Roman"> <o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><FONT size=3><FONT
face="Times New Roman"><SPAN lang=EN-GB style="mso-ansi-language: EN-GB">I
shown anymore. I use tiffs with 256 colors. Now, the </SPAN><SPAN lang=EN-US
style="mso-ansi-language: EN-US">grayscale </SPAN><SPAN lang=EN-GB
style="mso-ansi-language: EN-GB">tiffs are v! isible, the colormapped are not.
If the grayscale tiffs are visible, the color of the shape-polygons are not as
set in the map file!<o:p></o:p></SPAN></FONT></FONT></P>
face="Times New Roman">Using ms4 and linux, all tiffs are shown without any
problems.<o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal
style="MARGIN-TOP: 0cm; MARGIN-BOTTOM: 0cm; MARGIN-RIGHT: 0px"><SPAN
lang=EN-GB style="mso-ansi-language: EN-GB"><FONT size=3><FONT
style="mso-ansi-language: EN-GB"><FONT face="Times New Roman" size=3>Maybe
there is a problem with a GDAL/GD <SPAN
style="mso-spacerun: yes"> </SPAN>in the windows version of mapserver 4?
I tried the </FONT></SPAN><A
href="http://mapserver.gis.umn.edu/win32bin/ms40_png_pg.zip"><SPAN lang=EN-GB
size=3>ms40_png_pg.zip</FONT></SPAN></A><SPAN lang=EN-GB
style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">
and <SPAN
style="mso-spacerun: yes"> </SPAN>mapserver-4.0-win32-php4.3.2.zip.<o:p></o:p></FONT></FONT></SPAN></P>
<P class=MsoNormal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN!
style="mso-ansi-language: EN-GB" -GB><FONT size=3><FONT
face="Times New Roman">Thank you,<o:p></o:p></FONT></FONT></SPAN></P>
face="Times New Roman">Robert<o:p></o:p></FONT></FONT></SPAN></P>
style="mso-ansi-language: EN-GB"><FONT size=3><FONT face="Times New Roman">!
<o:p></o:p></FONT></FONT></SPAN></P>______________________________________________________________________________<BR>Zwei
Mal Platz 1 mit dem jeweils besten Testergebnis! WEB.DE FreeMail<BR>und WEB.DE
Club bei Stiftung Warentest! <A
href="http://f.web.de/?mc=021183"><B>http://f.web.de/?mc=021183</B></A>
_______________________________________________ Mapserver-users mailing list
</BLOCKQUOTE></BODY></HTML>
------_=_NextPart_001_01C3836C.22190EC0--
