MapScript Documentation (Re: [Mapserver-users] Re: problem getting bounds of poly shape)
Lowell Filak
lfilak at medinaco.org
Thu Sep 25 15:30:53 EDT 2003
Strange, I just checked and my original reply to this must have never
exitted my machine.
The code you sent before actually constructed a shapeObj instead of a
rectObj for the queryByRect.
This is probably a legal thing to do but I just have to ask - are you
sure the queryByRect is producing the correct result?
Lowell
The following message was sent by "pkishor_98"
<pkishor at geoanalytics.com> on Wed, 24 Sep 2003 16:43:21 -0000.
> --- In mapserver-users at yahoogroups.com, Daniel Morissette
<morissette at d...>
> wrote:
> > I think we should do more use of bugzilla to track those kind of issues
> > once it's been established that something needs a fix (the getBounds()
> > thing in this case). The mailing list gets lots of traffic and chances
> > are that the conclusions of those discussions will be lost of forgotten
> > unless someone has time to act on the issues right away which is
unlikely.
> > By using bugzilla, we can later on track the reasons behind any change
> > back to the initial problem reported by the user (Puneet would be the
> > bug reporter in this case), and then we can read in each bug report the
> > discussions that led to a decision to change the behavior or not.
> > The use of bugzilla also makes it easier for developers and other
> > contributors (documentation, etc) to query the database and view a list
> > of current issues to work on *when* they have time.
> Thanks Daniel.
> I've added this in the bz as an enhancement request. Part of the
problem is that us
> non-developers still have to first figure out whether or not our
problem lies with us
> screwing up or with the code. We can only do that via the list. Of
course, once it is
> determined that indeed the problem is a "bug" then it can be added to
the zilla.
> For example, I am still having a problem with queryByShape, and I
don't know if I am
> doing something wrong or if this is a bug.
> My problem is thus --
> creating an shapeObj and then using it to queryByShape against a layer
returns way
> more results than should.
> getting the bounds of the above shape and creating a rectObj and then
using
> queryByRect against the same layer returns the correct number of
results (way less
> than that returned by queryByShape).
> now, I have to first determine if I am doing something obviously wrong
or if this is a
> bug. Then I can act accordingly.
> Many thanks.
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
