[Mapserver-users] Error compiling java mapscript classes (Mapserver 4.0)
GeoIT
info at geo-it.com
Mon Sep 29 07:17:28 EDT 2003
Dear list,
While making java mapscript module I receive the following errors:
pooka at mobilix:~/MS40/mapserver-4.0/mapscript/java
<mailto:pooka at mobilix:~/MS40/mapserver-4.0/mapscript/java>> make
/usr/local/bin/swig -java -shadow -package edu.umn.gis.mapscript mapscript.i
Deprecated command line option: -shadow. Proxy classes are now generated by
default.
gcc -fpic -c -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ -DUSE_PROJ_API_H
-DUSE_TIFF -DUSE_JPEG -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DUSE_OGR -DUSE_GDAL -I.
-I../../../gd-2.0.15gif -I/usr/local/include -I/usr/lib/java/include
-I/usr/lib/java/include/linux mapscript_wrap.c
gcc -fpic -shared mapscript_wrap.o -o libmapscript.so -L../.. -lmap
-L../../../gd-2.0.15gif -lgd -ljpeg -lfreetype -lpng -lz -ltiff -ljpeg
-lfreetype -lpng -lz -lproj -ljpeg -L/usr/local/lib -lgdal.1.1
-L/usr/local/pgsql/lib -lpq -L/usr/local/lib -lcurl -lz -lssl -lcrypto -ldl
-lz -lpthread -lm -lstdc++ -lstdc++
/usr/lib/java/bin/javac -d . *.java
outputFormatObj.java:134: setExtension(java.lang.String) is already defined
in edu.umn.gis.mapscript.outputFormatObj
public void setExtension(String extension) {
outputFormatObj.java:138: setMimetype(java.lang.String) is already defined
public void setMimetype(String mimetype) {
mapObj.java:299: clone() in edu.umn.gis.mapscript.mapObj cannot override
clone() in java.lang.Object; attempting to use incompatible return type
found : edu.umn.gis.mapscript.mapObj
required: java.lang.Object
public mapObj clone() {
3 errors
make: *** [mapscript_java] Fehler 1
Which occurence of the methods setExtension and setMimetype in class
outputFormatObj should I remove ?
The return Type in mapObj.clone() should be set to Object instead of mapObj.
Is it OK to do the chanches in the java source files ? I think they should
preferably done in the interface file, but I don't know how. Please advise !
My System configuration:
Mapserver 4.0
swig 1.3.19
Sun JDK 1.4.1_01
Thanks in advance for You help,
Regards,
Andreas Paukner-Ruzicka
Geo-IT GmbH - Geoinformatik, IT-Services
Guggenberg 3, D-82380 Peissenberg
Tel: 08803-498372, Fax: 08803-498373
eMail: info at geo-it.com - Homepage: http://www.geo-it.com
