[Mapserver-users] can I use different symbols in thesamedynamiclayer?
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Mon Sep 29 07:40:25 EDT 2003
>One layer is a collection of figures of some type, a class defines
>how a certain figure will be drawn based on a certain attribute
>(CLASSITEM) or characteristic, so, to draw differently two or more
>features on one layer, you must add as many classes as different
>colors (or symbols, etc) you need.
Sounds good to me, but why can I change the symbol on using only ONE
class?
>Exactly, that's why you need to set the class index in the
>$point->draw() call:
Whoops. There's the missing piece of the puzzle!
First of all I managed to draw two different colored symbols using two
static classe in my MapFile with specifying the particular class-index.
So far success. :-D
But my try to do this dynamically failed since I did'nt manage to
transfer the label-data into my new class.
What I did:
$newclass = ms_newClassObj($layer); // create a new class
$originalclass = $layer->getClass(0);
$newclass->set('name','new class');
$newclass->set('type', $originalclass->type );
$newclass->set('status', $originalclass->status ); // retrieve data
from previous class
$newclass->set('minscale',$originalclass->minscale ); // provide new
class with this data
$newclass->set('maxscale',$originalclass->maxscale );
$newclass->label=$originalclass->label; // transfer
label-information //THIS FAILES!
$style = ms_newStyleObj($newclass);
$style->color->setRGB(0, 255, 0);
$style->set ( 'symbol', $sym3 );
$pt->setXY( -4100000, 2500000 );
$pt->draw($map, $layer, $image, 1, "Pt3"); // use new class
=> index=1
$map->save('test3.map');
The output of test3.map shows:
LAYER
NAME "p"
SIZEUNITS PIXELS
STATUS ON
TOLERANCE 0
TOLERANCEUNITS PIXELS
TYPE POINT
UNITS METERS
CLASS
LABEL
SIZE MEDIUM
TYPE BITMAP
BUFFER 0
COLOR 0 0 0
FORCE FALSE
MINDISTANCE -1
MINFEATURESIZE -1
OFFSET 0 0
PARTIALS TRUE
POSITION AUTO
END
STYLE
COLOR 0 255 0
MAXSIZE 100
MINSIZE 1
SIZE 40
SYMBOL 17
END
END
CLASS
NAME "new class" // okay here's my new class - but no
label-data
STYLE
COLOR 0 255 0
MAXSIZE 100
MINSIZE 1
SIZE 1
SYMBOL 1
END
END
END
So one problem solved and another one found?
>Another way to do this is through addFeature(), this is the way i do it
>because i usually need to add polygons and lines besides points, i'll
>send an example if needed.
Yes a example would be a great help!
TIA,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
