[Mapserver-users] can I use different symbols in thesamedynamiclayer?
Daniel Morissette
morissette at dmsolutions.ca
Tue Sep 30 08:36:53 EDT 2003
Frieso ter Haseborg wrote:
> Even if this gets slowly off topic - if you will excuse me - what's
> wrong with $newclass->label=$originalclass->label;
> I must have a wrong understanding of the class-handling in
> PHP/MapScript. I thought I could transfer the whole sub-class (member)
> e.g. the label with all it's attributes set to another class. At least
> when I use a class in a class with pure PHP such operations are no
> problems, the sub-class with all it's attributes is given to the new
> class.
You can't do this with PHP MapScript. The reason is that the MapScript
classes are not pure PHP classes, they are just wrappers on top of the
low-level C structures. When you assign label objects this way, only
the PHP wrapper part of the object is copied, but the low-level C
structure is not modified. That's the same reason why you need to use
the set() methods to set class member variables and cannot set them
directly.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
