[Mapserver-users] Mapserver 3D extension
Norman Vine
nhv at cape.com
Tue Sep 30 14:30:20 EDT 2003
Tyler Mitchell writes:
> Indeed interesting. Did you find that the web page you reference worked
> okay? I couldn't get it to work but I'm wondering if it's my java setup,
> but not sure.
Hi Tyler
FWIW - in general I find bottom posting friendlier :-)
There have been many similar falure reports but
I have never had a problem after
1) Installing a web-enabled Java distribution
I happen to use 1.4.1
2) then installing the Java 3D extensions
It seems as if the order of installation makes a difference
There is a slightly newer version @
http://www.vso.cape.com/~nhv/maps/3d/
The large 'details test' < not on on the older page >
demonstrates a canned view from my current 3D mapserver
testbed which can include arbritary vector overlays as returned
from a standard mapserver query
Note the base texture can be anything < satelite photo etc >
These examples use a dynamically created pseudo sun shaded
elevation map
Alas this project is on hold as funding didn't materialize
Cheers
Norman
> mapserver-users-admin at lists.gis.umn.edu wrote on 09/30/2003 09:49:48 AM:
> > Hello all:
> > A few months ago, Norman Vine posted this,
> > http://www.seascallop.com/Norman_Vine/Gulf_of_Maine3D.html interesting
> > implementation to the list.
> > Has anyone tried on this direction since? Can you send an example of such
> > implementation to the list if you did.
> > Thanks,
> > Gayathri Swaminathan
