[Mapserver-users] Isolines
woodbri at swoodbridge.com
Tue Sep 30 16:19:55 EDT 2003
There is no support for isolines in mapserver. If you want to do
something like that you will have to write an application outside of
mapserver that generates the isolines based on some dataset and
extracts them into a shapefile (or equiv) and request mapserver to
serve up the temporary file that was created with the isolines.
I do some similar to this to compute iso drivetime curves for
drivetime analysis. see http://imaptools.com/demos1/?tab=3
-Steve W.
On 1 Oct 2003 at 4:25, Diego de Abelleyra wrote:
> Hello,
> Have someone worked with isolines in mapserver, like for example
> temperature isolines? Is it posible to do with mapserver?
> Thamks,
> Diego de Abelleyra.
> Buenos Aires,
> Argentina
> ----- Original Message -----
> From: "Patrick J Barabe" <pbarabe at U.Arizona.EDU>
> To: "Umberto Nicoletti" <unicoletti at prometeo.it>
> Cc: < >
> Sent: Tuesday, September 30, 2003 3:10 PM
> Subject: Re: [Mapserver-users] Java mapserver HOWTO and questions
> > Hi Umberto,
> > Your HOWTO was very useful to me in compiling java mapscript on
> > Solaris. Thanks for submitting this to the list.
> > Now that I'm looking at the javadocs I compiled, I'm exactly sure
> > how to implement the java module. Do you have some sample JSP code
> > I could take a look at that demos just bit of core functionality?
> > Also, should libmapscript.so from the java build directory go
> > anywhere in particular, or is is sufficient to add this directory to
> > $LD_LIBRARY_PATH?
> > Thanks in advance,
> > Patrick Barabe
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
