[Mapserver-users] problem with mapserver4 and postgres
collao_andres
collao_andres at hotmail.com
Tue Sep 30 19:36:24 EDT 2003
hello I have compiled to mapserver 4, and I can use LABEL and SHAPE
without problems, but when trying to read from the data base in
Postgres 7.3.2/PostGIS 0,7,5 does not show respective layer. I have
tried of everything, but nothing seems to give result; only stranger
who happens is that when making this consultation in postgres appears
the following message
parse error at or near "geom" at character
in the past, this aplication run without problem over mapserver 3.6.6
and when start with version 4 I modified the Mapfile
You have any idea??
MAP
NAME "FIRSTMAP"
STATUS ON
#EXTENT -5696501 1923039 5696501 11022882
EXTENT 251537 6338840 258665 6344780
SIZE 400 400
SHAPEPATH "/usr/local/apache2/htdocs/alberto/"
IMAGETYPE png
IMAGECOLOR 255 255 255
UNITS METERS
WEB
IMAGEPATH "/usr/local/apache2/htdocs/tmp/"
IMAGEURL "/tmp/"
END
OUTPUTFORMAT
NAME "png"
MIMETYPE "image/png"
DRIVER "GD/PNG"
EXTENSION "png"
IMAGEMODE PC256
TRANSPARENT FALSE
END
PROJECTION
"proj=utm"
"zone=19"
"south"
"ellps=intl"
"towgs84=-288,175,-376,0,0,0,0"
"units=m"
"no_defs"
END
LAYER
NAME "SAMPLE GRID"
PROJECTION
"proj=utm"
"zone=19"
"south"
"ellps=intl"
"units=m"
"no_defs"
END
TYPE LINE
STATUS ON
CLASS
COLOR 255 255 128
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 255 100 50
END
END
GRID
MINSUBDIVIDE 64
MAXSUBDIVIDE 64
#ABELFORMAT "DDMM"
END
END
LAYER
NAME "ssd"
STATUS ON
DATA "comunas"
TYPE POLYGON
UNITS METERS
SIZEUNITS PIXELS
TOLERANCE 0
TOLERANCEUNITS PIXELS
CLASS
TEMPLATE "void"
STYLE
SYMBOL 0
COLOR 255 255 255
OUTLINECOLOR 200 200 200
SIZE 1
MINSIZE 1
MAXSIZE 100
END
END
END
LAYER
NAME "ejes_calles"
STATUS ON
DATA "the_geom from ejes_calles"
TYPE LINE
CONNECTIONTYPE POSTGIS
CONNECTION "user=admin password=admin dbname=valparaiso
host=localhost port=5432"
UNITS METERS
SIZEUNITS METERS
TOLERANCE 0
CLASS
NAME "calles_zoom_5"
STYLE
#SYMBOL 0
COLOR 0 0 0
SIZE 10
END
END
END
END
