Mapserver's WFS-client problems - Can't get it to work
Alexandre Florio
aflorio at GISPLAN.COM.BR
Wed Aug 4 13:39:34 EDT 2004
I'm having problems while trying to access a WFS-server (Geoserver 1.2.0-rc2) through Mapserver's WFS-client support. Mapserver's version is 4.2.1.
This is how my WFS-client layer is set up:
LAYER
NAME "acervo_espacial"
TYPE POLYGON
CONNECTIONTYPE WFS
CONNECTION "http://localhost:8080/geoserver/wfs"
STATUS ON
METADATA
"wfs_version" "1.0.0"
"wfs_service" "WFS"
"wfs_typename" "gisplan:acervo_espacial"
END
PROJECTION
"init=epsg:4291"
END
END
This is the error message from Mapserver:
msDrawMap(): Image handling error. Failed to draw layer named 'acervo_espacial'.
msWFSLayerWhichShapes(): WFS connection error. WFS request produced unexpected output (junk?) for layer acervo_espacial.
I have already tried setting up the layer passing the WFS parameters (version and typename) directly in the CONNECTION parameter, via GET, without success.
The "junk" that Mapserver talks about is a .gml file containing a "ServiceExceptionReport" node:
<?xml version="1.0" ?>
<ServiceExceptionReport
version="1.2.0"
xmlns="http://www.opengis.net/ogc"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd">
<ServiceException locator="org.vfny.geoserver.requests.readers.XmlRequestReader">
XML getFeature request SAX parsing error: org.xml.sax.SAXException: Attempted to construct illegal filter: Got to the end state of an incomplete filter, current state is rightValue
(java stack trace)
</ServiceException>
</ServiceExceptionReport>
Geoserver returns correct GML when I send a 'GetFeature' request using a browser:
(http://localhost:8080/geoserver/wfs?request=GetFeature&typename=gisplan:acervo_espacial returns valid GML)
This is the request that Mapserver is sending to Geoserver (I got it using netcat, listening in a different port set up in the CONNECTION parameter):
POST /geoserver/wfs HTTP/1.1
Host: localhost:5555
Pragma: no-cache
Accept: image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, */*
Content-Type: text/xml
Content-Length: 305
<GetFeature
service="WFS"
version="1.0.0"
outputFormat="GML2">
<Query typeName="gisplan:acervo_espacial">
<Filter>
<BBOX>
<PropertyName>Geometry</PropertyName>
<Box>
<coordinates>-77.038333,-37.435044 -31.038333,8.511622</coordinates>
</Box>
</BBOX>
</Filter></Query>
</GetFeature>
Which seems good to me, but Geoserver complains that the Filter is invalid (see the exception description above).
Does anybody know what can be wrong here?
Alexandre
