symbol question
Bart van den Eijnden
bartvde at XS4ALL.NL
Thu Aug 5 10:09:59 EDT 2004
Thanks. Your tip got it working.
Here's the solution for the record.
SYMBOL
NAME "fence"
TYPE truetype
FONT "monospace"
CHARACTER "X"
GAP 10
END
CLASS
EXPRESSION /8192|8191|8190/
NAME "fence"
STYLE
SYMBOL "circle"
COLOR 0 0 0
SIZE 1
END
OVERLAYSYMBOL 'fence'
OVERLAYCOLOR 0 0 0
OVERLAYSIZE 10
END
Best regards,
Bart
> If I understand correct what he wants is to draw a line with the symbol.
> In that case you have to use a overlay of 2 symbols.
> Search the archive or the wiki for a railway lines examples.
> LALO
> El jue, 05-08-2004 a las 09:39, Emil Zegers escribió:
>> Hello Javier,
>> I've included an image to show how it looks on my machine.
>> I'm working with MapServer 4.2.
>> I don't know from what version up symbols with -99 -99 coding are
>> supported but I suppose you have an older version?
>> Probably updating MapServer will fix it.
>> Here the layer definition I use with the "hek" symbol:
>> LAYER
>> NAME ACN
>> METADATA
>> "wms_title" "ACN"
>> END
>> PROJECTION
>> "init=epsg:28992"
>> END
>> TYPE POINT
>> STATUS ON
>> MAXSCALE 25000
>> DATA "acn"
>> CLASS
>> SIZE 8
>> SYMBOL "hek"
>> NAME 'ACN'
>> COLOR 255 0
>> END # CLASS
>> END # LAYER
>> Regards,
>> Emil Zegers
>> >>> Javier Castillejo Montes <jcastil1 at tragsa.es> 08/05/04 02:25pm >>>
>> -----Mensaje original-----
>> De: Javier Castillejo Montes
>> Enviado el: jueves, 05 de agosto de 2004 14:25
>> Para: 'UMN MapServer Users List'
>> Asunto: RE: [UMN_MAPSERVER-USERS] symbol question
>> Hi Emil
>> I tried your simbol, but how can i do to show one simbol after other, i
>> mean, instead on have the simbol X--X--X--X (more or less is the
>> simbol,
>> isn't it? :-) What I get is in each piont of the line a simbols is
>> drawn
>> so it does not appear as a simbol, just a line a bit bigger that if I
>> don't
>> use the simbol
>> Below is the result i had!!
>> any ideas?
>> ______________________________________________________
>> This message has been checked for all known viruses
> Eduardo Spremolla <edspremolla at antel.com.uy>
> Antel I+D
