SLD Question
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Thu Aug 5 13:58:13 EDT 2004
Hi There,
You could also check few examples of sld usage on the mapserver's wiki
page, that might help you if the problem is with sld syntax :
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?SLDMapServer
Later,
Alexandre Florio wrote:
> Hi,
> I can't get SLD to work. What are the requirements?
> Isn't it enough to have Mapserver compiled with support to WMS? Do I have to put some
> metadata information in the .map file?
> This is the request I'm using to test:
> http://localhost/cgi-bin/mapserv?SERVICE=WMS&VERSION=1.1.1&Request=GetMap&LAYERS=uf&SLD=http://localhost/prototipo-gis/test.xml&map=prototipo-gis/prototipo-gis-wms.map
> I should be able to see, in the webserver's logs, Mapserver trying to fetch the file "test.xml", right? Nothing shows up there, except the request above...
> I'm using latest Mapserver version 4.2.2.
> Thanks in advance
> Alexandre
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
