Fwd: Re: [Mapserver-users] Fw: help on mygis
Lowell Filak
lfilak at MEDINACO.ORG
Fri Aug 6 08:32:05 EDT 2004
http://dev.mysql.com/doc/mysql/en/Spatial_extensions_in_MySQL.html
The following message was sent by "pablo" <pablo_schmitt_ at hotmail.com>
on Thu, 5 Aug 2004 19:42:49 -0300.
> i need mygis manual,,,, exists ?????
> ----- Original Message -----
> From: "Lowell Filak" <lfilak at medinaco.org>
> To: "pablo_schmitt_" <pablo_schmitt_ at hotmail.com>;
> <mapserver-users at lists.gis.umn.edu>
> Sent: Thursday, July 29, 2004 11:09 AM
> Subject: Re: [Mapserver-users] Fw: help on mygis
> > I don't know mygis but as a quick fix you could join all the attributes
> > into the first layer so there is no relate required to do the
labelling.?
> > Lowell
> > The following message was sent by "pablo_schmitt_"
> > <pablo_schmitt_ at hotmail.com> on Thu, 29 Jul 2004 09:47:43 -0300.
> > > From: pablo_schmitt_
> > > To: mapserver-users at lists.gis.umn.edu
> > > Sent: Wednesday, July 28, 2004 6:59 PM
> > > Subject: help on mygis
> > > hello friends
> > > i need some help from you
> > > this is a brief description of my problem:
> > > i have a grupos2002.shp file uploaded into mysql using the
> > shp2mysql.lp, > and it is working properly
> > > this script generated the following tables geometry_columns,
> > grupos2002, > grupos2002_bin, grupos2002_num
> > > , spatial_ref_sys
> > > in the map file i have this definition for the connection and data:
> > > CONNECTION "localhost:gisusr:gis:gisdb:bin:"
> > > DATA "geometry from grupos2002 feature, grupos2002_bin geometry"
> > > and it is working fine
> > > my problem is:
> > > i have a table zonas with the following fields:
> > > 1- f_Zona ( olso located in grupos2002 )
> > > 2- Description
> > > 3- Atributos
> > > so, i need to use the field number 2 ( Description) as Label in the
> > map > and i need to apply some filters using the field number
> > > 3 (Atributos).
> > > THE BIG CUESTION IS: how should i contruct my DATA definition in the
> > map > file ????
> > > i hope you could understand me
> > > thank you very much
> > > by
> > > pablo schmitt
> > > municipalidad de malvinas argentinas
> > > dep. informática
