MapScript (centering a dynamic point layer)
Steven Monai
stevem at SPATIALMAPPING.COM
Fri Aug 6 11:37:42 EDT 2004
Jerod:
Check out the mapObj->setextent() method, here:
http://mapserver.gis.umn.edu/doc42/phpmapscript-class-guide.html#MapObj
(you'll have to scroll down the page a bit to find it).
My suggestion: What you'll want to do is to get the minimum and maximum x
and y coordinates from your set of points, call the setextent() method with
those values, and then, finally, call the draw() methods to draw the map.
A PHP implementation is left as an exercise for the reader, but the code
below looks like a good starting point.
Hope this helps,
-SM
On Thu, 5 Aug 2004 17:36:58 -0500, Jerod Clabaugh <jclabaugh at MAC.COM> wrote:
>Hi:
>I am just working my into the PHP/Mpascript world so bear with me.
>I am working to show a list of information about a biological
>specimen, displaying the locality of the specimen as a point on a
>small map.
>I can generate such a small map on-the fly by generating a dynamic
>point layer pulling UTM coordinates from PostgreSQL/PostGIS db (with
>dummy point layer in map file). No problems so far.
>My problem is that some species aren't showing up on these maps b/c
>they are not in the 'frame' (further south or north of the area of
>the map being drawn). I need to readjust the map to center on the
>point being drawn.
>I know that this likely requires adjusting the extents and using the
>zoompoint method, but other than that I'm lost.
>[Specs: Mapserver 4.2.2, PHP 4.3.7 CGI, Apache2, PostgreSQL 7.4.2
>with PostGIS 0.81; all functional.]
>I have looked online and at the mapscript wiki but all the examples I
>find are trying to capture a user's click on a ma and my attempts to
>modify that code have failed. Any help you can give me is much
>appreciated.
>Cheers,
>Jerod Clabaugh
>=-=-=PHP CODE=-=-=
> //load Mapscript
> dl('php_mapscript.so');
> // generate and execute the query
> $connection = pg_connect("user=xxxx dbname=xxxx host=localhost");
> $query = "SELECT data_specimen.easting,
>data_specimen.northing from data_specimen WHERE
> data_specimen.specimen_id = '$dcid'";
> $result = pg_exec($connection, $query);
> // get the number of rows in the resultset
> $rows = pg_numrows($result);
> // MapObj and ImageObj settings
> $map_path="/Library/Apache2/htdocs/demo1.map";
> $map = ms_newMapObj($map_path);
> $img = $map->draw();
> //get dummy point layer
> $layer = $map->getLayerByName("species");
> ///turn dummy point layer status to ON
> $layer->set('status', MS_ON);
> //loop through resultset, generating the points
> for ($i=0; $i<$rows; ++$i) {
> $row = pg_fetch_row($result, $i);
> $pt = ms_newPointObj();
> $pt->setXY($row[0],$row[1]);
> $pt->draw($map, $layer, $img, 0, "TEST");
> //create map image
> $img_url=$img->saveWebImage(MS_PNG,1,1,0);
> // close database connection
> pg_close($connection);
>=-=-=HTML CODE =-=-=
><img src="<?php echo $img_url?>" border="1">
>=-=-=MAP FILE DUMMY POINT LAYER=-=-=
>LAYER
> NAME species
> TYPE POINT
> STATUS OFF
> CLASS
> COLOR 255 255 0
> OUTLINECOLOR 0 0 0
> SYMBOL 'triangle'
> SIZE 8
> END
>END
