Win32 Mapserver build failure
Mark Leslie
mark at REFRACTIONS.NET
Mon Aug 9 18:48:39 EDT 2004
I am having trouble with a building Mapserver 4.2.2 on a Windows 2000
machine. I built it with Proj, freetype compiled from source and gd
windows binaries dist using the attached makefile. I'm using MS's build
tools (cl, nmake, lib, link). Once compiled, mapserv -v returns what is
expected, but accessing it through via Apache gives an application
error: "memory could not be written". Running mapserv
QUERY_STRING="..." was not helpful, since QUERY_STRING was not
recognized, but shp2img produced the same error. The map file I'm
attempting to use (attached) is from the mapserver recipes page, and
runs fine on a linux build.
I'm at my wits end with this, and would really appreciate any thoughts
you might have.
Mark
# makefile.vc - Main MapServer makefile for MSVC++
# This VC++ makefile will build MAPSERVER.LIB, MAPSERV.EXE, and the other
# MapServer command-line programs.
# To use the makefile:
# - Open a DOS prompt window
# - Run the VCVARS32.BAT script to initialize the VC++ environment variables
# - Start the build with: nmake /f makefile.vc
# $Id: Makefile.vc,v 1.45 2004/04/13 20:41:22 assefa Exp $
MAPSERVER_ROOT = .
# nmake.opt - MapServer 4.x configuration for MSVC++
# This VC++ configuration is used in building MAPSERVER.LIB, MAPSERV.EXE,
# and the other MapServer command-line programs.
# $Id: nmake.opt,v 1.4 2004/04/12 18:38:24 assefa Exp $
# Contents:
# Section I: Mapserver Options (you may want to edit)
# Section II: Support Libraries (you must edit)
# Section III: Debug Flags (no need to edit)
# Section IV: Variable Setup (should not need to edit)
# Section V: UMN GIS System Setup (should not need to edit)
# Section VI: Collect compiler flags
MS_LIB = mapserver.lib
MS_LIB_DLL = mapserver_i.lib
# Uncomment the following to link mapserv.exe withh dll
DLLBUILD=1
# Input raster format options:
# The lite version of mapserver 4.x supports only PNG and JPEG data for input.
# If you wish to support any of the following raster formats you will need
# the GDAL support library from http://www.remotesensing.org/gdal.
# Once you have the library, set the flag below to compile with GDAL and
# provide the full path to GDAL project directory
# Format Name
# Arc/Info ASCII Grid AAIGrid
# Arc/Info Binary Grid (.adf) AIG
# Microsoft Windows Device Independent Bitmap (.bmp) BMP
# BSB Nautical Chart Format (.kap) BSB
# CEOS (Spot for instance) CEOS
# First Generation USGS DOQ (.doq) DOQ1
# New Labelled USGS DOQ (.doq) DOQ2
# Military Elevation Data (.dt0, .dt1) DTED
# ERMapper Compressed Wavelets (.ecw) ECW
# ESRI .hdr Labelled EHdr
# ENVI .hdr Labelled Raster ENVI
# Envisat Image Product (.n1) Envisat
# EOSAT FAST Format FAST
# FITS (.fits) FITS
# Graphics Interchange Format (.gif) GIF
# Arc/Info Binary Grid (.adf) GIO
# GRASS Rasters GRASS
# TIFF / GeoTIFF (.tif) GTiff
# Hierarchical Data Format Release 4 (HDF4) HDF4
# Erdas Imagine (.img) HFA
# Atlantis MFF2e HKV
# Japanese DEM (.mem) JDEM
# JPEG2000 (.jp2, .j2k) JPEG2000
# JPEG2000 (.jp2, .j2k) JP2KAK
# NOAA Polar Orbiter Level 1b Data Set (AVHRR) L1B
# Atlantis MFF MFF
# NITF NITF
# OGDI Bridge OGDI
# PCI .aux Labelled PAux Yes
# Netpbm (.ppm,.pgm) PNM Yes
# USGS SDTS DEM (*CATD.DDF) SDTS
# SAR CEOS SAR_CEOS
# USGS ASCII DEM (.dem) USGSDEM
# X11 Pixmap (.xpm) XPM
#GDAL=-DUSE_GDAL
#GDAL_DIR=c:\MSSDE\gdal-1.2.1
# Input vector format options
# The lite version of Mapserver 4.x only suports ESRI shapefiles for input.
# If you wish to support any of the following vector formats you will need
# the GDAL support library with OGR from http://www.remotesensing.org/gdal.
# Once you have the library, set the flag below to compile with OGR and
# Format Name
# Arc/Info Binary Coverage
# FMEObjects Gateway
# IHO S-57 (ENC)
# Mapinfo File
# Microstation DGN
# OGDI Vectors
# Oracle Spatial
# PostgreSQL
# SDTS
# UK .NTF
# U.S. Census TIGER/Line
#OGR=-DUSE_OGR
#GDAL_DIR=c:\projects\gdal
#ECW support
#ECW is one of the formats supported through GDAL. If you have built
#gdal with ECW support, you need to link it with the ECW librarires.
#uncommnet the following lines to have the ECW support.
#ECW_DIR= C:\projects\ECW_SDK
#Xerces support
#If GDAL was compoiled with the Xerces support, you need to use the
#xerces library. #uncommnet the following line to have the Xerces support
#XERCES_DIR = c:\projects\xerces-c1_6_0-win32
# Comment out the following to disable ODBC support.
#ODBC_SUPPORTED = 1
# Tiff Input
# Tiff input is also available through GDAL. If you wish to build to support
# TIFF input without GDAL you will need to unccomment the following flag
# and set the full path to the project directory containing libtiff.
# See http://www.libtiff.org/ for support library
#TIFF=-DUSE_TIFF
#TIFF_DIR=c:\MSSDE\tiff-v3.6.1
# JPEG Input:
# JPEG input for raster layers is also available through GDAL, If you wish
# to build support for JPEG without GDAL, uncomment the following flag
# and provide the full path to the jpeg support library project directory.
# See http://www.ijg.org/ for support library.
#JPEG=-DUSE_JPEG
#JPEG_DIR=c:/projects/gdal/frmts/jpeg/libjpeg
# Output format options:
# If you wish to allow JPEG output maps, uncomment the following flag
#OUTPUT_JPEG=-DUSE_GD_JPEG
#JPEG_DIR=c:\MSSDE\gdal-1.2.1\frmts\jpeg\libjpeg
# If you wish to allow PNG output maps, uncomment the following flag
# and provide the full path to the png and zlib support library project
# directories.
# See http://www.libpng.org/pub/png/libpng.html for support library.
# See http://www.gzip.org/zlib/ for support library.
#OUTPUT_PNG=-DUSE_GD_PNG
#PNG_DIR=c:\MSSDE\lpng125
#ZLIB_DIR=c:\MSSDE\zlib121
# If you wish to allow Windows BMP output maps, uncomment the following flag.
OUTPUT_WBMP=-DUSE_GD_WBMP
# If you wish to have FLASH output, uncomment the following flag and provide
# the full path to the MING support library project directory.
# See http://ming.sourceforge.net/ for support library.
#MING=-DUSE_MING_FLASH
#MING_DIR=c:/projects/ming-0.2a
#MING_DIR=c:/projects/ming-0.3beta1
# If you wish to have PDF output, uncomment the following flag and provide the
# full path to the PDF support library project directory.
# See http://www.pdflib.com/ for support library.
#PDF=-DUSE_PDF
#PDF_DIR=c:/projects/pdflib-4.0.3
# Annotation fonts.
# If you wish to annotate your maps with true type fonts unccomment the
# following flag. Provide the full path to the FreeType 2.x external
# supprt library. See http://www.freetype.org for support library.
ANNOTATION_FT=-DUSE_GD_FT
FT_DIR=c:\MSSDE\freetype-2.1.9
# Direct connectivity to Postgresql PostGIS.
# To turn on direct connectivity to Postgresql PostGIS uncomment the following
# flag and set the full path name to the project directory for the
# Postgresql native Win32 client library.
# See http://www.postgresql.org for support library.
#POSTGIS =-DUSE_POSTGIS
#POSTGIS_DIR =c:/projects/libpq
#Orcale
#ORACLE_DIR = c:\Oracle\Ora81
#ORACLE=-DUSE_ORACLESPATIAL
#OGDI
#OGDI_DIR = c:\projects\ogdi-3.1.0
#OGDI_LIB = $(OGDI_DIR)\lib\ogdi31.lib
# Direct connectivity to ArcSDE.
# To turn on direct connectivity to ArcSDE uncomment the following
# flag and set the full path name to the project directory for ArcSDE.
# Since ESRI includes the version number in the name of their libraries
# you may need to change that number in Section III of this configuration
# file.
# See http://www.esri.com/software/arcgis/arcinfo/arcsde/index.html for
# support library
#SDE_OPT=-DUSE_SDE -DWIN32
#SDE_DIR=c:\arcgis\arcsde
# EPPL7 Support
# This activates ERDAS as well. It is included in the distribution.
# Probably the best raster alternative if
# you've got EPPL7 laying around. See http://www.lmic.state.mn.us/ for
# more information.
# Uncomment out the following flag and set the full path name to the
# epplib.obj file.
#EPPL=-DUSE_EPPL
#EPPL_OBJ=c:/my_path/epplib.obj
# If you want to ignore missing datafile errors uncomment the following
# line. This is especially useful with large tiled datasets that may not
# have complete data for each tile.
IGNORE_MISSING_DATA=-DIGNORE_MISSING_DATA
NEED_NONBLOCKING_STDERR=-DNEED_NONBLOCKING_STDERR
ENABLE_STDERR_DEBUG=-DENABLE_STDERR_DEBUG
# If you want antialiasing (note that It requires gd2)
USE_GD_ANTIALIAS=-DUSE_GD_ANTIALIAS
# Use this flag to compile with WMS Server support.
# To find out more about the OpenGIS Web Map Server Specification go to
# http://www.opengis.org/
WMS=-DUSE_WMS_SVR
# Use this flag to compile with WMS Client support. WMS Client support
# allows you to pull layers from other OGIS WMS servers on the interent and
# incorporate them into your map.
# you need the libcurl library from http://curl.haxx.se/library/c/
# Set the full path to the curl project directory.
# You will also need to set the full path to the Microsoft Visual C++ windows
# socket library.
#WMSCLIENT= -DUSE_WMS_LYR
#CURL_DIR=c:/projects/curl-7.10.2
#CURL_DIR=c:\MSSDE\curl-7.12.0
#WINSOCK_LIB = "C:\Program Files\Microsoft SDK\Lib\WSOCK32.LIB"
# Use -DUSE_WFS_SVR to compile with WFS server support, requires OGR and PROJ4
# Use -DUSE_WFS_LYR to compile with WFS client support, requires libcurl
#WFS=-DUSE_WFS_SVR
#WFSCLIENT= -DUSE_WFS_LYR
# Reprojecting.
# If you would like mapserver to be able to reproject data from one
# geographic projection to another, uncomment the following flag
# Proj.4 distribution (cartographic projection routines).
# Not required for normal use. (EXPERIMENTAL)
# For PROJ_DIR use full path to Proj.4 distribution
PROJ=-DUSE_PROJ -DUSE_PROJ_API_H
PROJ_DIR=c:\MSSDE\proj-4.4.8
# PHP Mapscript.
# If you plan to build PHP mapscript uncomment the following flag and
# set the full path to the PHP project directory
#PHP=1
#PHP_DIR=c:\projects\php-4.3.4
# Apparently these aren't as commonplace. Edit the
# following line to reflect the missing functions on your platform.
#STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRDUP
STRINGS=-DNEED_STRCASECMP -DNEED_STRNCASECMP -DNEED_STRLCAT
# Section II: External Support Libraries
# You will need to set the paths to various support library projects
# that you have compiled.
# GD Library.
# Mapserver 4.x only supports GD 2.x and greater.
# Sorry no more GIF support. If you need GIF support you will
# need to run Mapserver 3.6.x with GD 1.2.
# GD is a required support library for MapServer 4.x.
# Enter the full path to your GD 2.x project directory
# Note : A patched version of GD that supports GIF, JPEG, PNG and WBMP can be
# downloaded from http://www.rime.com.au/gd/. If you are using this library,
#you should uncomment the following line
OUTPUT_GIF=-DUSE_GD_GIF -DGD_HAS_GDIMAGEGIFPTR
GD_DIR=c:/MSSDE/gdwin32
# REGEX Libary
# VC++ does not include the REGEX library... so we must provide our one.
# The following definitions will try to build GNU regex-0.12 located in the
# regex-0.12 sub-directory.
# If it was not included in the source distribution, then you can get it from:
# ftp://ftp.gnu.org/pub/gnu/regex/regex-0.12.tar.gz
# Provide the full path to the REGEX project directory
# You do not need this library if you are compiling for PHP mapscript.
# In that case the PHP regex library will be used instead
!IFNDEF PHP
REGEX_DIR=c:\MSSDE\regex-0.12
!ENDIF
# Section III: Debug flags
# Should not need to be updated.
# DEBUG Build flags
# Set the DEBUG flag if you wish to make a debug build
#DEBUG=/DDEBUG
# Set the Warning level for the compiler (defaults to W1)
WARNING_LEVEL=/W3
# Set the linker debug option
LDEBUG=/debug
# Proj.4 include and library
!IFDEF PROJ_DIR
PROJ_INC=-I$(PROJ_DIR)\src
PROJ_LIB=$(PROJ_DIR)\src\proj.lib
!ENDIF
# CURL include and library
!IFDEF WMSCLIENT
CURL_INC = -I$(CURL_DIR)\include
CURL_LIB = $(CURL_DIR)\lib\libcurl.lib
!ENDIF
# Set the jpeg library
!IFDEF OUTPUT_JPEG
JPEG_LIB=$(JPEG_DIR)\libjpeg.lib
!ENDIF
# Set the png support libaries
!IFDEF OUTPUT_PNG
PNG_LIB=$(PNG_DIR)\libpng.lib $(ZLIB_DIR)\zlib.lib
!ENDIF
# Set the FreeType library
!IFDEF ANNOTATION_FT
#FT_LIB=$(FT_DIR)\objs\freetype211.lib
FT_LIB=$(FT_DIR)\objs\freetype.lib
!ENDIF
# GD include and library
GD_INC= -I$(GD_DIR)
GD_LIB= $(GD_DIR)\bgd.lib \
$(JPEG_LIB) $(PNG_LIB) $(FT_LIB)
GD= $(OUTPUT_PNG) $(OUTPUT_JPEG) $(OUTPUT_WBMP) $(OUTPUT_GIF) $(ANNOTATION_FT)
# Tiff library on input
!IFDEF TIFF
TIFF_INC=-I$(TIFF_DIR)\libtiff
TIFF_LIB=$(TIFF_DIR)\libtiff\libtiff.lib
!ENDIF
# JPEG library on input
!IFDEF JPEG
!ENDIF
# Setup GDAL includes and libraries
!IFDEF GDAL
GDAL_INC = -I$(GDAL_DIR)\gcore -I$(GDAL_DIR)\alg
GDAL_LIB = $(GDAL_DIR)\gdal_i.lib
!ENDIF
# Setup OGR includes and libraries
!IFDEF OGR
OGR_INC = -I$(GDAL_DIR)\ogr\ogrsf_frmts -I$(GDAL_DIR)\ogr -I$(GDAL_DIR)\ogr\..\port
OGR_LIB = $(GDAL_DIR)\ogr\ogrsf_frmts\ogrsf_frmts.lib $(GDAL_DIR)\ogr\ogrsf_frmts\ogrsf_frmts_sup.lib $(GDAL_DIR)\ogr\ogr.lib $(GDAL_DIR)\ogr\..\port\cpl.lib
!ENDIF
# Setup ESRI SDE support.
!IFDEF SDE_OPT
SDE_INC=-I$(SDE_DIR)\include
SDE_LIB=$(SDE_DIR)\lib\sde90.lib $(SDE_DIR)\lib\sg90.lib $(SDE_DIR)\lib\pe90.lib
!ENDIF
#ECW support
!IFDEF ECW_DIR
ECW_LIB=$(ECW_DIR)\lib\NCSEcw.lib $(ECW_DIR)\lib\NCSEcwC.lib \
$(ECW_DIR)\lib\NCSUtil.lib
!ENDIF
#Xerces support
!IFDEF XERCES_DIR
XERCES_LIB=$(XERCES_DIR)\lib\xerces-c_1.lib
!ENDIF
!IFDEF ODBC_SUPPORTED
ODBC_LIB = "C:\Program Files\Microsoft Visual Studio\VC98\Lib\ODBC32.lib"
!ENDIF
# Setup REGEX object and includes
!IFNDEF PHP
REGEX_OBJ=$(REGEX_DIR)\regex.obj
REGEX_INC=-I$(REGEX_DIR)
!ELSE
REGEX_OBJ=$(PHP_DIR)\regex\regcomp.obj $(PHP_DIR)\regex\regerror.obj \
$(PHP_DIR)\regex\regexec.obj $(PHP_DIR)\regex\regfree.obj
REGEX_INC=-I$(PHP_DIR)\regex -DPHP_NO_ALIASES
!ENDIF
# REGEX needs some special flags... here they are for VC++ 6.0
REGEX_OPT=-DHAVE_STRING_H -DREGEX_MALLOC
# Setup Postgesql PostGIS includes and libs
# Note that the Postgresql includes are not used in the compilation of
# PHP/MapScript. The reason is that there is a name conflict between the
# regex/regex.h files used in PHP and Postgresql. This is not a real issue
# since they are two completely different interfaces. The issue arrises when
# the php_regex.h trys to include regex/regex.h and gets the wrong one from
# postgresql. Therefore we do not give it that opertunity by not providing the
# include path.
!IFDEF POSTGIS
!IFNDEF PHP_BUILD_CALL
#POSTGIS_INC=-I$(POSTGIS_DIR)\src\interfaces\libpq -I$(POSTGIS_DIR)\src\include
POSTGIS_INC=-I$(POSTGIS_DIR)\interfaces\libpq -I$(POSTGIS_DIR)\include
!ENDIF
#POSTGIS_LIB=$(POSTGIS_DIR)\src\interfaces\libpq\release\libpqdll.lib
POSTGIS_LIB=$(POSTGIS_DIR)\interfaces\libpq\libpqdll.lib
POSTGIS_OBJ=mappostgis.obj
!ENDIF
# Setup FLASH includes and libs
!IFDEF MING
MING_INC=-I$(MING_DIR)\src -I$(MING_DIR)
MING_LIB= $(MING_DIR)\src\libming.lib
#MING_VERSION=-DMING_VERSION_03
!ENDIF
# Setup PDF includes and libs
!IFDEF PDF
PDF_LIB=$(PDF_DIR)\pdflib\pdflib.lib
PDF_INC=-I$(PDF_DIR)\pdflib
!ENDIF
#Oracle support
!IFDEF ORACLE
ORACLE_INC=-I$(ORACLE_DIR)\oci\include
ORACLE_LIB=$(ORACLE_DIR)\oci\lib\msvc\oci.lib
!ENDIF
# Section V: UMN GIS System Support
# UofMN GIS/Image Processing Extension (very experimental)
#EGIS=-DUSE_EGIS
!IFDEF EGIS
ERR_DIR=c:/my_path_to/errLog
ERR_OBJ=$(ERR_DIR)/errLog.o
ERR_INC=-I$(ERR_DIR)
ERR_LIB=-L$(ERR_DIR) -lerrLog
IMGGEN_DIR=c:/my_path_to/imgSrc
IMGGEN_OBJ=$(IMGGEN_DIR)/imgLib.o
IMGGEN_INC=-I$(IMGGEN_DIR)
IMGGEN_LIB=-L$(IMGGEN_DIR) -limgGEN
!ENDIF
EXTERNAL_LIBS=$(GD_LIB) $(TIFF_LIB) $(JPEG_LIB) \
$(PROJ_LIB) $(OGR_LIB) $(GDAL_LIB)\
$(CURL_LIB) $(MING_LIB) $(PDF_LIB) \
$(WINSOCK_LIB) $(POSTGIS_LIB) $(IMGGEN_LIB) $(ERR_LIB) \
$(XERCES_LIB) $(ECW_LIB) $(ORACLE_LIB) $(OGDI_LIB) $(ODBC_LIB) \
$(SDE_LIB) $(REGEX_OBJ)
LIBS=$(MS_LIB) $(EXTERNAL_LIBS)
LIBS_DLL=$(MS_LIB_DLL) $(EXTERNAL_LIBS)
INCLUDES=$(GD_INC) $(TIFF_INC) $(JPEG_INC) \
$(PROJ_INC) $(REGEX_INC) $(GDAL_INC) $(OGR_INC) \
$(CURL_INC) $(MING_INC) $(PDF_INC) $(POSTGIS_INC) \
$(IMGGEN_INC) $(ERR_INC) $(ORACLE_INC) $(SDE_INC)
MS_CFLAGS=$(INCLUDES) $(REGEX_OPT) $(STRINGS) $(POSTGIS) \
$(EPPL) $(PROJ) $(TIFF) $(JPEG) $(GD) $(OGR) $(WMS) \
$(WMSCLIENT) $(MING) $(IGNORE_MISSING_DATA) $(NEED_NONBLOCKING_STDERR) \
$(GDAL) \
-DFEATURE_INFO_HTML $(WFS) $(WFSCLIENT) $(PDF) $(EGIS) \
$(USE_GD_ANTIALIAS) $(ORACLE) $(MING_VERSION) $(SDE_OPT)
OPTFLAGS = /nologo /Zi $(WARNING_LEVEL) $(DEBUG)
BASE_CFLAGS = $(OPTFLAGS) -DWIN32 -D_WIN32 -MT
LDFLAGS = /NODEFAULTLIB:msvcrt /NODEFAULTLIB:libcd /DEBUG
#LDFLAGS = /NODEFAULTLIB:libcd /DEBUG
CFLAGS=$(BASE_CFLAGS) $(MS_CFLAGS)
CC= cl
LINK= link
# Main MapServer library.
MS_DLL = libmap.dll
MS_OBJS = mapbits.obj maphash.obj mapshape.obj mapxbase.obj \
mapparser.obj maplexer.obj mapindex.obj maptree.obj \
mapsearch.obj mapstring.obj mapsymbol.obj mapfile.obj \
maplegend.obj maputil.obj mapscale.obj mapquery.obj \
maplabel.obj maperror.obj mapprimitive.obj mapproject.obj\
mapraster.obj cgiutil.obj mapsde.obj mapogr.obj maptime.obj \
maptemplate.obj mappostgis.obj maplayer.obj mapresample.obj \
mapwms.obj mapwmslayer.obj mapgml.obj maporaclespatial.obj \
mapprojhack.obj mapdraw.obj mapgd.obj mapoutput.obj mapswf.obj \
mapgdal.obj mapwfs.obj mapwfslayer.obj mapows.obj maphttp.obj \
mappdf.obj mapcontext.obj mapdrawgdal.obj mapjoin.obj mapgraticule.obj \
mapmygis.obj mapimagemap.obj mapcopy.obj \
mapogcfilter.obj mapogcsld.obj mapthread.obj $(EPPL_OBJ) $(REGEX_OBJ)
MS_HDRS = map.h mapfile.h
MS_EXE = mapserv.exe \
shp2img.exe legend.exe \
shptree.exe scalebar.exe sortshp.exe tile4ms.exe shptreevis.exe
default: all
all: $(MS_LIB) $(MS_EXE)
$(MS_OBJS): $(MS_HDRS)
$(MS_LIB): $(MS_OBJS)
# copy $(GDAL_DIR)\gdal.pdb .
lib /out:$(MS_LIB) $(MS_OBJS)
link /dll /debug /nodefaultlib:libc.lib /nodefaultlib:msvcrt.lib \
$(MS_OBJS) $(EXTERNAL_LIBS) \
"c:\Program Files\Microsoft Visual Studio .NET 2003\Vc7\lib\MSVCRT.lib" \
"c:\Program Files\Microsoft SDK\Lib\WinMM.lib" \
/out:$(MS_DLL) /implib:$(MS_LIB_DLL)
$(MS_EXE): $(LIBS)
gd::
cd gd-1.2
nmake /f makefile.nt OPTFLAGS="$(OPTFLAGS)"
cd ..
.c.obj:
$(CC) $(CFLAGS) /c $*.c /Fo$*.obj
.cpp.obj:
$(CC) $(CFLAGS) /c $*.cpp /Fo$*.obj
.c.exe:
!IFDEF DLLBUILD
$(LINK) $(LDFLAGS) $*.obj $(LIBS_DLL)
!ELSE
$(LINK) $(LDFLAGS) $*.obj $(LIBS)
!ENDIF
.cpp.exe:
clean:
del *.obj
del $(REGEX_OBJ)
del *.lib
del *.dll
del $(MS_EXE)
del *.pdb
del *.exp
del *.ilk
# cd gd-1.2
# nmake -f makefile.nt clean
# cd ..
MAP
NAME HELLO
STATUS ON
EXTENT 0 0 4000 3000
SIZE 400 300
IMAGECOLOR 200 255 255
WEB
IMAGEPATH "C:\WWW\image\"
IMAGEURL "localhost:8080/image/"
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
200 150
END
TEXT 'Hello world. Mapserver rocks.'
END
CLASS
LABEL
TYPE BITMAP
COLOR 0 0 0
END
END
END
END
