Problem with Mapserver 4.2
Bart van den Eijnden
bartvde at XS4ALL.NL
Tue Aug 10 05:07:34 EDT 2004
are you using the windows binaries from mapserver.gis.umn.edu or the
binaries from maptools.org?
I would suggest to try the maptools.org binaries and see if they fix your
problem.
http://www.maptools.org/dl/mapserver-4.2.2-win32-php4.3.7.zip
Best regards,
Bart
> Thanks bart I have solved the dependacy problem but I have an error that
> is almost the same as the one posted first
> "[Tue Aug 10 16:36:51 2004] [error] [client 127.0.0.1] malformed header
> from script. Bad header=GIF87aö ô ç: mapserv.exe"
> I am using TIF images not GIF images...
