Problem using OGR VRT data
    Frank Warmerdam
    warmerdam at POBOX.COM
    Wed Aug 11 11:55:52 PDT 2004
Matthew Holger wrote:
> I've been trying to get an OGR VRT layer to work under mapserver 4.2.2, but I
> keep running into trouble.
> Using ogrinfo to view the individual layers specified in my .ovf file, I have
> no problems, but when trying to access the data with mapserver I get an
> internal server error, with no diagnostics in my Apache error logs, and the
> only thing seen in my apache trace logs being a query for geometry_columns
> (which I created by finessing the shp2mysql.pl script, using ogr2ogr to dump
> the layer using the ovf file to a shape file, then reimporting the shapefile,
> finessing the newly create geometry_columns table, then dropping the other
> tables created by shp2mysql).  Messy, but it worked...
> (The specific query I see is:
> SELECT f_table_name, f_geometry_column, geometry_type FROM geometry_columns
> limit 136662716
> But...the last number (136662716) changes from time to time...)
> What I find curious is that the geometry_columns table isn't referenced by
> ogrinfo, and in the mapserver source I only see it referenced in MyGIS and
> PostGIS, of which I'm using neither.
Matthew,
The SELECT statement you reference is normal with the ODBC driver. If it
finds a GEOMETRY_COLUMNS table it will try to define a set of spatial layers
based on that table rather than the list of all tables (or a list provided in
the dataset name).  I don't know where the "limit 136662716" part is coming
from.  I can't see anything in my code that generates that.  Perhaps something
in the ODBC middle where adds it?
As for why things are working with ogrinfo, and not within MapServer, I
really don't know.  All the "usual" reasons could apply:
  o did you *really* rebuild MapServer with the new OGR?  Replacing the
    DLL is not sufficient.
  o Are you sure you understand all the ODBC and file permissions issues involved?
  o Are you sure the .ovf file is even being found?
  o Are you sure you are escaping things properly in the .ovf file?  ie. Does the
    ovf file work properly with ogrinfo or just the direct ODBC connection?
Best regards,
More information about the MapServer-users
