What's Wrong With This Picture?
Ed McNierney
ed at TOPOZONE.COM
Thu Aug 12 19:09:03 EDT 2004
Barbara -
It looks like you did pretty well!
Your EXTENT line in the map file should be MINX MINY MAXX MAXY - you've
got the two Y values reversed, which means you're asking for nothing
(and getting it <g>). Try just swapping those two numbers.
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
Phone: +1 978 251-4242 Fax: +1 978 251-1396
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Barbara Zack
Sent: Thursday, August 12, 2004 5:29 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] What's Wrong With This Picture?
My apologies for bothering the list with this, but I'm running out of
time. I'm primarily a programmer with almost no GIS background. Being
the only available entity, I was asked to get MapServer up and running
as a WMS server. Obviously I have no business doing this, but here I am.
I managed to get a Linux server (Debian sarge) up and running, GDAL
compiled with mrsid support, MapServer compiled, and the demo working.
The map file part is beyond my comprehension. The one I put together,
only half of which I actually understands, produces an XML capabilities
document with no warning messages. However, GetMap gives me a blank png
as output. Below are the results of mapserv -v and gdalinfo in case
that's important. Following that is my first attempt at a map file, for
your amusement. I don't understand about half of what I have in there.
Any pointers would be so greatly appreciated.
Thanks!
Barbara Z
./mapserv -v
MapServer version 4.2.2 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER INPUT=EPPL7
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
gdalinfo /var/www/aviano/aviano.sid
Driver: MrSID/Multi-resolution Seamless Image Database (MrSID) Size is
89286, 111281 Coordinate System is `'
Origin = (311999.989722,5105471.083134)
Pixel Size = (0.06720000,0.06720000)
Metadata:
IMAGE__COLOR_SCHEME=0
IMAGE__DATA_TYPE=0
IMAGE__INPUT_FILE_SIZE=0.000000
IMAGE__WIDTH=89286
IMAGE__HEIGHT=111281
IMAGE__XY_ORIGIN=312000.023322,5105471.116734
IMAGE__X_RESOLUTION=0.067200
IMAGE__Y_RESOLUTION=0.067200
Corner Coordinates:
Upper Left ( 311999.990, 5105471.083)
Lower Left ( 311999.990, 5112949.166)
Upper Right ( 318000.009, 5105471.083)
Lower Right ( 318000.009, 5112949.166)
Center ( 314999.999, 5109210.125)
Band 1 Block=89286x64 Type=Byte, ColorInterp=Red Band 2 Block=89286x64
Type=Byte, ColorInterp=Green Band 3 Block=89286x64 Type=Byte,
ColorInterp=Blue ===========================================
MAP
EXTENT 311999.990 5112949.166 318000.009 5105471.083
IMAGETYPE png
SIZE 783 976
PROJECTION
"init=epsg:4326"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE PC256
EXTENSION "png"
END
WEB
METADATA
"wms_title" "Aviano Map"
"wms_onlineresource"
"http://sid/cgi-bin/mapserv?map=/var/www/aviano/aviano.map&"
"wms_srs" "EPSG:4326"
END
END
LAYER
NAME "Aviano1"
DATA "/var/www/aviano/aviano.sid"
TYPE raster
STATUS on
METADATA
"wms_title" "Aviano Raster"
END
CLASSITEM "[pixel]"
CLASS
EXPRESSION ([pixel] < 64)
COLOR 0 0 0
END
CLASS
EXPRESSION ([pixel] >= 64 AND [pixel] < 128)
COLOR 255 0 0
END
CLASS
EXPRESSION ([pixel] >= 128 AND [pixel] < 196)
COLOR 0 255 0
END
CLASS
EXPRESSION ([pixel] >= 196 AND [pixel] < 256)
COLOR 0 0 255
END
END
END
