Multiple geometry types in singlelayer
    Judd, Chris
    Chris.Judd at DEP.STATE.FL.US
    Fri Aug 13 06:12:48 PDT 2004
Steve,
Many thanks for your reply.
-Chris
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: Thursday, August 12, 2004 4:35 PM
To: Judd, Chris; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Multiple geometry types in
singlelayer
MapServer relies on the layer TYPE to decide how to render a feature.
The feature type (obtained from that datasource) is used for error
checking.
You can draw a polygon feature using a line layer and a line or polygon
feature using a point layer. You can't draw a point as a polygon though.
So, if the Oracle Spatial  driver in MapServer allows access to multiple
feature you probably can do some simple stuff, but you couldn't set up
EXPRESSIONs to capitalize on the type of a feature. At this point you'd
have to filter based on feature type at the connection level, that is,
just deal with all the points in one layer and so on.
Steve
>>> "Judd, Chris" <Chris.Judd at DEP.STATE.FL.US> 8/12/2004 2:52:02 PM
MapServer folks,
We are looking to use MapServer to serve Oracle Spatial data that has
multiple geometry types (points, lines and polygons) in a single
layer.
Many databases support multiple geometry types in the same layer.  This
is a
quote from the SDE wiki
(http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?MapServerSDE) "SDE
techically
allows for storage of multiple geometry types in the same layer..."  I
believe PostGIS has also added this feature.
We were able to mine Google and find this post from Paul Ramsey dated
2001,
stating at that time MapServer could only render one geometry type per
layer.
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0110/msg00187.html
My questions are:
1) Does the current version of MapServer support the rendering of more
than
one geometry type in a single layer?
2) Is there an example of this?  Any example would be helpful.
Thanks for your support.
Chris Judd
Florida DEP
More information about the MapServer-users
