problematic map file
Oliver Ishmael
oliver_ishmael at HOTMAIL.COM
Mon Aug 16 18:31:16 EDT 2004
Hi All,
I have been trying to display a map of the world using the attached .MAP
file (also displayed below), however, this has met with limited success.
All that i have managed to display is the .HTML template, unfortunately no
image is displayed and no error messages are displayed.
It might be a lot to ask but if you can see anything i've missed i would
really appreciate any help you can provide.
Cheers
Oliver Ishmael
MAP
NAME world_tm
IMAGETYPE PNG
EXTENT 148.3 198.0 198.0 120.7
SIZE 600 400
SHAPEPATH "mapserver/data/"
# Index of
colours...http://webmonkey.wired.com/webmonkey/reference/color_codes/
IMAGECOLOR 95 158 180
WEB
TEMPLATE 'world_tm.html'
IMAGEPATH '../mapserver/data/tmp/'
IMAGEURL '../mapserver/data/tmp/'
END
PROJECTION
# this code can be found in the "epsg.file" (when opened in txt ed. it
lists every projection
# and their respective epsg codes)
"init=epsg:2156"
# for some reason this projection is usually dif from the layer
projection...why?!
END
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
# Start of LAYER DEFINITIONS ---------------------------------------------
LAYER # African continent polygon layer begins here
NAME Africa
DATA Africa
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Egypt using UTM (just picked a country in
Africa at random!)
"init=epsg:4198"
END
CLASS
COLOR 255 255 0
OUTLINECOLOR 255 255 0
END
END # African continent polygon layer ends here
LAYER # Asian continent polygon layer begins here
NAME Asia
DATA Asia
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for India (just picked a country in Asia at
random!)
"init=epsg:4238"
END
CLASS
COLOR 178 34 34
END
END # Asian continent polygon layer ends here
LAYER # Australasian continent polygon layer begins here
NAME Australasia
DATA Australasia
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Australia (just picked a country in Australasia
at random!)
"init=epsg:4002"
END
CLASS
COLOR 178 34 34
END
END # Australian continent polygon layer ends here
LAYER # European continent polygon layer begins here
NAME Europe
DATA Europe
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Ireland using UTM (just picked a country in
Europe at random!)
"init=epsg:2156"
END
CLASS
COLOR 178 34 34
END
END # European continent polygon layer ends here
LAYER # North American continent polygon layer begins here
NAME NorthA
DATA NorthA
STATUS DEFAULT
TYPE POLYGON
PROJECTION
# this is the exact code for Illinois (just picked a state in North America
at random!)
"init=epsg:26770"
END
CLASS
COLOR 178 34 34
END
END # North American continent polygon layer ends here
LAYER # South American continent polygon layer begins here
NAME SouthA
DATA SouthA
STATUS OFF
TYPE POLYGON
PROJECTION
# this is the exact code for Brazil (just picked a country in South America
at random!)
"init=epsg:28992"
END
CLASS
COLOR 178 34 34
END
END # South American continent polygon layer ends here
# End of LAYER DEFINITIONS ---------------------------------------------
END # end of map file/object
_________________________________________________________________
Use MSN Messenger to send music and pics to your friends
http://www.msn.co.uk/messenger
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040816/05ef9099/world_tm.html
MAP
NAME world_tm
IMAGETYPE PNG
STATUS ON
UNITS MILES
SIZE 600 400
SHAPEPATH "/localhost/mapserver/data"
# Index of
IMAGECOLOR 120 158 13
WEB
END
PROJECTION
"init=epsg:2156"
projection...why?!
END
SCALEBAR
LABEL
COLOR 0 0 0
SIZE TINY
END
STYLE 1
SIZE 200 2
COLOR 0 0 0
UNITS MILES
INTERVALS 2
TRANSPARENT FALSE
STATUS ON
END
NAME Africa
DATA Africa
STATUS ON
TYPE POLYGON
PROJECTION
Africa at random!)
"init=epsg:4198"
END
CLASS
COLOR 255 255 0
END
NAME Asia
DATA Asia
STATUS ON
TYPE POLYGON
PROJECTION
random!)
"init=epsg:4238"
END
CLASS
COLOR 178 34 34
END
NAME Australasia
DATA Australasia
STATUS ON
TYPE POLYGON
PROJECTION
Australasia at random!)
"init=epsg:4002"
END
CLASS
COLOR 178 34 34
END
NAME Europe
DATA Europe
STATUS ON
TYPE POLYGON
PROJECTION
Europe at random!)
"init=epsg:2156"
END
CLASS
COLOR 178 34 34
END
NAME NorthA
DATA NorthA
STATUS ON
TYPE POLYGON
PROJECTION
at random!)
"init=epsg:26770"
END
CLASS
COLOR 178 34 34
END
NAME SouthA
DATA SouthA
STATUS ON
TYPE POLYGON
PROJECTION
at random!)
"init=epsg:28992"
END
CLASS
COLOR 178 34 34
END
