mapfile - REQUIRES
Zamil Murji
Zamil.Murji at DIVESTCO.COM
Tue Aug 17 12:45:17 EDT 2004
Hello list,
I get the following error when I use REQUIRES as part of my layer. Everything works fine if I take out the REQUIRES.
getString(): Symbol definition error. Parsing error near ([wells] != 1):(line 32)
Here is the relevant parts of my .map file.
rasterlogs is the layer in question, I only want to query it if wells is turned off.
LAYER
NAME "wells"
# DEBUG on
TYPE point
STATUS off
MAXSCALE 800000
CONNECTIONTYPE postgis
CONNECTION "user=idc dbname=idc host=idcmap port=5432"
# DATA "the_geom from main_well2"
DATA "the_geom from (select oid, to_date(main_well2.spud_date, 'YYYY-MM-DD') as pretty_spud_date, to_date(main_well2.rig_release_date, 'YYYY-MM-DD') as pretty_rig_release_date, prettyuwi(main_well2.uwi) as prettyuwi, well_status(plot_symbol) as well_status, * from main_well2) as new_table using unique oid"
TEMPLATE "./idcdev_tooltip_wells.html"
PROJECTION
"init=epsg:4269"
END
END
LAYER
NAME "rasterlogs"
TYPE point
STATUS off
MAXSCALE 800000
REQUIRES ([wells] != 1)
FILTER "raster_log = 'Y'"
PROJECTION
"init=epsg:4269"
END
END
Here is the URL i'm sending (I replaced the ip address with xxx):
http://xxx.xx.xxx.xx/cgi-bin/mapserv?mode=nquery&map=/mapfiles/idcdev_canada_tooltip-query.map&imgext=75211.88879+3662074.25847+87345.05967+3671730.41522&mapsize=867+690&imgbox=557+361+567+371&source=SHD477&layers=wells+rasterlogs
Thanks for your help...
Zamil
