Building and display scalebar object using python mapscript
Sean Gillies
sgillies at FRII.COM
Tue Aug 17 16:58:20 EDT 2004
On Aug 17, 2004, at 2:28 PM, William Hudspeth wrote:
> Hello,
> Does anyone have a code snippet illustrating building and displaying a
> scalebar object using python mapscript?
> Thanks, Bill
Bill,
Say you have a mapObj instance named 'the_map'. You can modify
properties
of the map's scalebar like
the_map.scalebar.height = 10
the_map.scalebar.width = 100
See the mapscript documentation at
http://users.frii.com/sgillies/projects/mapscript/4.2/mapscript.html
for details of scalebar properties.
The scalebarObj class has no drawing methods of its own, you have to
draw it through methods of the parent mapObj. drawScalebar returns an
instance of imageObj:
scalebar_image = the_map.drawScalebar()
You can save the image to disk for use
filename = 'scalebar.%s' % (scalebar_image.format.extension)
scalebar_image.save(filename)
You can also embed the scalebar in the map image
map_image = the_map.draw()
the_map.embedScalebar(map_image) # puts scalebar into label cache
the_map.drawLabelCache(map_image)
Hope this helps,
Sean
Sean Gillies
sgillies at frii dot com
