Problem compiling Mapserver
Michael Schulz
mschulz at WEBGIS.DE
Wed Aug 18 09:38:46 EDT 2004
Welcome Etienne,
I assume you want to start using mapserver/python/zmapserver on windows since you mention a dos
command bar, is that right? I would suggest using precompiled binaries instead of compiling
everything on your own.
Have a look at http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PythonMapScript
there you will find links where to download precompiled python/mapscript binaries ("External
Links"). You will need one of these (depending on your requirements, with oraclespatial, etc.) to
use zmapserver.
Be careful to choose packages that use the same python version, e.g. if you use zope2.7 this will
mean you have to use python2.3 and accordingly choose the mapscript/python build.
After you have installed the python/mapscript binary you can start using mapscript in a python shell
and you can use zmapserver with zope.
HTH, Michael
Etienne Desgagné schrieb:
> Hi everyone, I'm new here and I have problem to start compiling mapserver. I
> have download and install Python and Mapserver and I just want to compile
> mapserver. It's problably funny (I must begin somewhere...) but I don't know
> where to type the ./configure --with... . In a dos command bar? My project
> is to install Plone/Zope and ZmapServer after that.
> Thanks!
> Etienne.
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
