PDF Output
ANDY CANFIELD
andy_canfield at HOTMAIL.COM
Wed Aug 18 13:18:12 EDT 2004
Well it looks like nobody has answered this yet so here is how I do it:
function MakePdfDoc($gbPdfPath){
GLOBAL $m_Map;
GLOBAL $gbBDisplayPdfLink;
//this function is just a wrapper that I use to get the maps cuurrent
bounds
//you can do this however you want
$Bounds = GetCurrentBounds();
//Set the width and hieght to reflect the resolution I want in the PDF
$m_Map->set("width",1200);$m_Map->set("height",1200);
//set the map extent
$m_Map->setextent($Bounds[0],$Bounds[1],$Bounds[2],$Bounds[3]);
//change the output format I use gif as my map format but it doesn't go to
pdf well
//so change to png for this
$m_Map->selectOutputFormat('png');
//This function simply loops through my layer settings and makes sure
everything I want
//in the pdf is currently set to ON
ApplyPdfLayers();
//draw the image
$imgToPdf = $m_Map->draw();
//save the image
$urlForPng = $imgToPdf->saveWebImage();
//create a new pdf memory chunk and get a handle to it
$my_pdf = pdf_new();
//open it for write
pdf_open_file($my_pdf);
//the path format for this cannot be relative
//so in IIS i concatenate this with the relative path returned by
//$imgToPdf->saveWebImage(); and that gives me the full path to the image
$wroot = "C:/somedir/somedir/somedir/";
$wroot.=$urlForPng;
$urlForPng=$wroot;
//open the image file and get a handle to that binary read content
$element = pdf_open_image_file($my_pdf,"png",$urlForPng);
//start a new page in the pdf
pdf_begin_page($my_pdf,1200,1200);
//place the image into the page
pdf_place_image($my_pdf,$element,0,0,1);
//close the read of the image
pdf_close_image($my_pdf,$element);
//end the page
pdf_end_page($my_pdf);
//close the pdf for write
pdf_close($my_pdf);
//extract the pdf contents into a variable
$data = pdf_get_buffer($my_pdf);
//reset the map for web drawing and redraw it
$m_Map->set("width",$Bounds[4]);$m_Map->set("height",$Bounds[5]);
$m_Map->selectOutputFormat('gif');
$m_Map->draw();
//at this point our pdf is simply a buffer in memory it doesn't have an
actual
//file on the server so I create a file on the server in a temp directory
and push
//the pdf buffer to it. I have a function that generates a unique pdf path
for their session
//so one session can write multiple pdfs but they simply overwrite the last
one that user
//created. This ensures that they can't clog my server with pdf's. If they
don't choose
//to download it then the next time they create one it will overwrite their
last one.
$handle = fopen($gbPdfPath,"w");
fwrite($handle,$data);
//close the file now we have a pdf on the server
fclose($handle);
//I use this flag to set whether or not to display a pdf link in a cell
//on my web page that points to the newly created pdf.
$gbBDisplayPdfLink = TRUE;
_________________________________________________________________
Dont just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
