Mapserver crash on text Flash (SWF) output... known problem?
    Reuven Levitt
    reuven at LEVITT.NET
    Mon Aug 23 10:00:51 PDT 2004
Hi Everyone,
I am relatively new to Mapserver, but have spent the
last 6 days working around 12 hours a day.  So I am
definitly getting some experience.  It is an amazing
piece of software !
The Flash output stuff I wrote works well (including
the demo on the Mapserver site).  However when I try
and get Mapserver to output any type of text to flash
output Mapserver simply crashes (On windows XP).
This only happens when
                FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
however it does not crash with:
                FORMATOPTION "OUTPUT_MOVIE=SINGLE"
Crash means windows: "mapserv.exe has encountered a
problem and needs to close.  We are sorry for the
inconvenience."
I created a very simple test case to see if it still
crashes, and it does.  Here is the map file:
MAP
        NAME FMV
        STATUS ON
        IMAGETYPE swf
        SIZE 800 600
        SHAPEPATH      "data"
        IMAGECOLOR     255 255 255
        EXTENT -180 -80 180 80
        FONTSET
"E:\Dev\Source\web\workshop\fonts\font.list"
#       EXTENT 0 0 20 20
        PROJECTION "proj=latlong" END
        WEB
                log "./tmp/fmv.log"
                TEMPLATE  'fmv_template.html'
                IMAGEPATH './tmp/'
                IMAGEURL  'http://localhost/workshop/fmv/tmp/'
        END
        OUTPUTFORMAT
                NAME swf
                DRIVER "SWF"
                MIMETYPE "application/x-shockwave-flash"
                EXTENSION "swf"
                IMAGEMODE PC256
        END
        LAYER
                NAME "credits"
                STATUS DEFAULT
                TRANSFORM FALSE
                TYPE ANNOTATION
                FEATURE
                        POINTS
                                10 480
                        END
                        TEXT 'Made by Mapserver.'
                END
                CLASS
                        LABEL
                                TYPE TRUETYPE
                                FONT "arial"
                                POSITION CR
                                COLOR 0 0 0
                                SIZE 8
                        END
                END
        END
END
All the other files are the ones that come with the
mapserver flash demo (FMV).
MapServer version 4.2.0 OUTPUT=GIF OUTPUT=PNG
OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
 OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLI
ENT INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
Any help would be greatly appreciated !
Also if someone could test this on their setup to see
if it works that would be great.
Thanks
Reuven.
More information about the MapServer-users
