Dynamic map title
Steve Lime
steve.lime at DNR.STATE.MN.US
Mon Aug 23 16:49:39 EDT 2004
Have you just tried changing the class TEXT property, either via
MapScript or
the CGI? That is, don't set the text for the inline feature, set the
text for the
class used to draw that feature.
LAYER
NAME "subtit"
STATUS ON
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS 635 10 END
END
CLASS
LABEL
TYPE TRUETYPE
FONT verdana # verdana-italic
SIZE 12
POSITION LL
COLOR 80 130 0 # 160 90 0
END
TEXT "Special Title Text Goes Here!"
END
END
Just an idea...
Steve
>>> Stefanie Weykam <sweykam at TELELINE.ES> 8/23/2004 7:02:49 AM >>>
Hi again,
last week, I asked the list how to get a dynamic title on the map. The
title
string depends on the currently displayed theme.
I got a message back (see below, thanks Sean) but I didn't get any
further
and am still running around in circles. Apparently it is not possible
to
change the feature text.
I must add, that the string will be passed by a variable, it is not a
queriable value that belongs to the layer.
As an alternative I have been thinking in keeping a static head line
and add
a dynamic title just above the legend.
But the look is not too convincing either (limitations in style and
most of
all - string length!).
I also want the title to be embedded in the image object, not just HTML
text
written on top.
Does anybody have a good idea how to work around this limitation?
thanks,
Stefanie
On Aug 16, 2004, at 11:17 AM, Stefanie Weykam wrote:
> Hi all,
> I have an annotation layer, it contains a point (feature) and a
string
> to
> label this point.
> Actually, the string is the title of the map and I want to change it
> according to the currently displayed theme.
> Is there any feature object which can be set by MapScript? The Class
> Reference doesn't mention any. And, how do I change the color of the
> label?
> I always get error messages saying that the property (both color and
> text)
> don't exist or that the function setRGB() is undefined....???
> Which objects do have these properties - do I nedd colorObjects?
> styleObjects?? How do I create them?
> Thanks,
> Stefanie
> LAYER
> NAME "subtit"
> STATUS ON
> TRANSFORM FALSE
> TYPE ANNOTATION
> FEATURE
> POINTS 635 10 END
> TEXT "Species Richness" # "a species name"
> END
> CLASS
> LABEL
> TYPE TRUETYPE
> SIZE 12
> POSITION LL
> END
> END
> END
Stephanie,
Support for inline features is currently limited. You cannot
access a feature once it is in the feature "set".
The thing to do is to leave out the FEATURE block in your map
file, and insert a new feature as needed:
p = mapscript.pointObj(635, 10) # the point
s = mapscript.shapeObj(layer.type) # new shape to hold point
l = mapscript.lineObj() # point must be in a line
l.add(p) # add point to line
s.add(l) # add line to shape
s.text = 'Species Richness' # label for point
layer.addFeature(s)
layer.draw(map, image)
cheers,
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
