Multiple Symbols and Breadcrumbs
Lowell Filak
lfilak at MEDINACO.ORG
Mon Aug 23 10:24:12 EDT 2004
Have you tried placing the most recent point in it's own layer so a
different symbol can be used?
Lowell
The following message was sent by Antonio Agostini
<mapserver at INTERAMERICAN.US> on Tue, 24 Aug 2004 08:56:36 -0500.
> Hi All.
> I want to display breadcrumbs showing a vehicle's route. Right now it
works
> with one symbol for all points.
> How do I go about showing different symbols depending, for example, on the
> vehicle heading?
> I have 16 symbols defined in the map file, "bump0" to "bump15". Headings
> are numbers from 0 to 15. At runtime I build the symbol name and change it
> but it is only taking the last one and renders all points with that one.
> Here's some of my map file and code. Any help is greatly appreciated. I'm
> still learning and hope to contribute here very soon.
> #16 symbols like this
> SYMBOL
> NAME 'bump0'
> TYPE PIXMAP
> IMAGE 'images/bump-green-00.gif'
> END
> #This is the layer I currently use for rendering all with the same symbol
> LAYER
> NAME 'GRAPHIC2'
> TYPE POINT
> MINSCALE 0
> MAXSCALE 55000000000
> STATUS ON
> FEATURE
> END
> CLASS
> STYLE
> SYMBOL 'images/bump8grn.GIF'
> END
> END
> END
> #PHP Code
> //arr is an array with data like
(lat,long,heading,lat,long,heading,etc...)
> $pos=0;
> $heading=-1;
> for ($i=0; $i < $size/3; $i++) {
> $oShp=ms_newShapeObj(MS_SHAPE_LINE);
> $oLine=ms_newLineObj();
> // do this after the first point
> if ($pos>0) {
> if ($arr[$pos+2] <> $heading) { //detect heading
> change
> $heading = $arr[$pos+2];
> $mysymbol=$gpoMap->getSymbolByName
> ("bump".$heading); //load this heading's symbol from map file
> $myClass = $dummylayer2->getClass(0);
> $mystyle = $myClass->getstyle(0);
> $mystyle->set("symbol", $mysymbol);
> $oLine->addXY($arr[$pos+1],$arr[$pos]);
> $oShp->add($oLine);
> $dummylayer2->addfeature($oShp);
> else //do this for the first point
> $oShp->add($oLine);
> //Set the first point label
> $oShp->set("text",$Label);
> $dummylayer->addfeature($oShp);
> $pos=$pos+3; //skip three places to the next point
> $oShp->free;
> $oLine->free;
