Mapserver on WinXP - Flash Still Being difficult. Help
Reuven Levitt
reuven at LEVITT.NET
Tue Aug 24 17:13:14 EDT 2004
I find that the flash output is still being a little
bit difficult. I have a country outline layer display
no problem, and also I can display either the country
name labels or the city name labels (annotation
layers), but not both. Whichever comes first in the
map file is displayed, while the other has nothing
come out.
Is there a way around this problem, or am I doing
something to cause it.
Thanks,
Reuven.
--- Yewondwossen Assefa <assefa at DMSOLUTIONS.CA> wrote:
> The flash output does not support True type fonts.
> It uses fonts called
> "FDB". The reason is that the underlying library
> (ming) only supports
> those fonts. You can download some FDB fonts at the
> ming web site
> http://ming.sourceforge.net/.
> Reuven Levitt wrote:
> > Hey Robert,
> > I am quite new, but I am running Mapserver on XP
> so
> > far with no problems at all. TrueType font works
> > fine, however I am running into a problem using
> the
> > Flash (SWF) output with Multiple layers on text
> > output. I dont know if this is an XP specific
> problem
> > or one specific to my setup.
> > Reuven.
> > --- Robert <robert-fritz at WEB.DE> wrote:
> >>hello,
> >>does anybody have trouble to run mapserver on
> >>WindowsXP? i know, that there
> >>is a problem using truetype fonts
> >>for labeling and XP, but are there other known
> >>restrictions / problems?
> >>Are there differences between XP-versions (XPPro,
> XP
> >>TabletEdition, ...?)
> >>Thank you for your help,
> >>robert
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
