map EXTENT
Jacob Blankenship
jhblankenship at YAHOO.COM
Wed Aug 25 17:08:39 EDT 2004
Thank you for pointing out ogrinfo.exe. I have a
polygon shp file, for which ogrinfo is reporting the
EXTENT as {-106.645 25.837 -93.508 36.500 }. When I
add these to my map file and display the image, the
map is off center and very small. Below are my map and
html files.
Thank you in advance,
Jacob
** Map file
MAP
NAME TEXAS
STATUS ON
SIZE 400 300
IMAGETYPE GIF
IMAGECOLOR 240 240 240
SHAPEPATH "C:\Inetpub\wwwroot\ShapeFiles\TX\"
UNITS METERS
EXTENT -106 25 -93 36
WEB
IMAGEPATH "C:\Inetpub\wwwroot\Images\Tmp\"
IMAGEURL "C:\Inetpub\wwwroot\Images\Tmp\"
END
LAYER
NAME "TX counties"
TYPE POLYGON
STATUS ON
DATA "cty00"
CLASS
NAME "TX counties"
OUTLINECOLOR 60 60 60
COLOR 255 255 0
SYMBOL 0
END
END
END
** HTML file
<?php
dl("php_mapscript_42.dll");
$map_file="./texas.map";
$map = ms_newMapObj($map_file);
$image=$map->draw();
$image_url=$image->saveWebImage();
<HTML>
<HEAD>
<TITLE>US state boundaries</TITLE>
</HEAD>
<BODY>
$nMinX = <?php echo ( $map->extent->minx ); ?><br>
$nMinY = <?php echo ( $map->extent->miny ); ?><br>
$nMaxX = <?php echo ( $map->extent->maxx ); ?><br>
$nMaxY = <?php echo ( $map->extent->maxy ); ?><br>
<img src="<?php echo $image_url?>">
</BODY>
</html>
--- Brant Anderson <brant at MUDLABS.COM> wrote:
> Hi Oliver,
> There is a tool called 'ogrinfo' included with the
> GDAL package. It is
> very handy.
> To get a summary of 'dlgstlndoug.shp' I would type:
> ogrinfo dlgstlndoug.shp dlgstlndoug -so
> The output would be:
> INFO: Open of `dlgstlndoug.shp'
> using driver `ESRI Shapefile' successful.
> Layer name: dlgstlndoug
> Geometry: Line String
> Feature Count: 403
> Extent: (285509.105030, 5069677.370139) -
> (334172.948552,
> 5109545.047051) <-- This is the EXTENT value (minx,
> miny) - (maxx, maxy)
> Layer SRS WKT:
> (unknown)
> FNODE_: Integer (9.0)
> TNODE_: Integer (9.0)
> LPOLY_: Integer (9.0)
> RPOLY_: Integer (9.0)
> LENGTH: Real (19.11)
> DLGSTLNDOU: Integer (9.0)
> DLGSTLND_1: Integer (9.0)
> USCLASS: Integer (6.0)
> FLOW: Integer (1.0)
> S1: Real (6.1)
> S2: Real (6.1)
> S3: Real (6.1)
> S4: Real (6.1)
> S5: Real (6.1)
> S6: Real (6.1)
> S7: Real (6.1)
> S8: Real (6.1)
> S9: Real (6.1)
> S10: Real (6.1)
> ZONE: String (5.0)
> TROUT: String (2.0)
> WSR: String (1.0)
> PWI: String (1.0)
> STREAM__: String (60.0)
> UNSPLIT_IT: String (77.0)
> Hope that helps!
> Brant Anderson
> Oliver Ishmael wrote:
> > Hi Guys,
> > How do i find out the EXTENT of my map?
> > Any help greatly appreciated!
> > Cheers
> > Oliver Ishmael
_________________________________________________________________
> > It's fast, it's easy and it's free. Get MSN
> Messenger today!
> > http://www.msn.co.uk/messenger
Do you Yahoo!?
Win 1 of 4,000 free domain names from Yahoo! Enter now.
http://promotions.yahoo.com/goldrush
