size for lines not read from mapfile? Is it a bug?
David Fawcett
David.Fawcett at STATE.MN.US
Fri Aug 27 09:59:04 EDT 2004
Monica,
You haven't defined a symbol in your style. Add a symbol to the style.
e.g.
CLASS
NAME "Highways"
TEMPLATE "null"
STYLE
SYMBOL 'circle'
COLOR 168 56 0
SIZE 3
END
END
This assumes that you have a symbol in your symbols file of the name 'circle'.
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> Monica Socol <monicasocol at CUESTASYS.COM> 8/27/2004 8:43:17 AM >>>
Hi everyone,
I have a layer called "Highways" and I set the symbology for it as
follows:
CLASS
NAME "Highways"
TEMPLATE "null"
STYLE
COLOR 168 56 0
SIZE 3
END
END
But the line width is the same on the map with the one set as 1 for
Roads*.
If I change through the code the size to 3 (I am using mapscript), then
is shown correctly.
Is this a bug? Or I am missing something?
Thank you for any response,
Monica
