error handling TIFF image
Frank Warmerdam
fwarmerdam at GMAIL.COM
Wed Dec 1 12:20:02 EST 2004
On Wed, 1 Dec 2004 15:10:13 -0200, Eduardo Patto Kanegae
<lists at webmapit.com.br> wrote:
> Hi folks,
> I have a SPOT image and I´m using MapServer 3.6.6 but I´m getting the following error message when trying to test my mapfile using "mode=map":
> *drawTIFF(): Image handling error. Only colormapped and grayscale images are supported. *
> Band 1 Block=7690x1 Type=Byte, ColorInterp=Red
> Band 2 Block=7690x1 Type=Byte, ColorInterp=Green
> Band 3 Block=7690x1 Type=Byte, ColorInterp=Blue
> Band 4 Block=7690x1 Type=Byte, ColorInterp=Alpha
Eduardo,
Your basic problem is that the built-in TIFF support does not support
RGB or RGBA images. You need to use the GDAL link for reading
rasters if you really want to do.
Given your stated constraints of having to stick with 3.6.6 and not
being able to re-compile with GDAL added to the mix, it seems you
will have to reprocess your image externally into a form suitable
for use with this version of mapserver.
You can use the rgb2pct.py script distributed with GDAL to convert
an RGB image to a pseudo-colored image you can use.
However, I can't stress enough that it will be very difficult to
get support from the community for a version of Mapserver as
antique as 3.6.6.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
