Shapefile field problem
Abe Gillespie
agillesp at VT.EDU
Thu Dec 2 13:02:05 EST 2004
Well, I'll keep plug'n along and maybe I'll stumble across something.
When I reach the point where there's nothing left but get this fixed
I'll do so then. I never got an answer, can I simply post the
problematic shapefile to the group? Is that user-group kosher?
And here's a sneak peak at the site I'm developing. It is in current
development so some things maybe broken, but it's working pretty good
now (i.e. only the address search is working). I'm pretty proud of it
and it's a testament to MapServer's power: http://141.152.79.120/ashe/
I'll make an official announcement when it's completed. And don't
worry, I'll definitely get a MapServer logo link up when it goes
public. :)
Thanks.
-Abe
On Dec 2, 2004, at 12:27 PM, Frank Warmerdam wrote:
> On Thu, 2 Dec 2004 12:39:46 -0500, Abe Gillespie <agillesp at vt.edu>
> wrote:
>> Like I said, I used ogrinfo and everything looked fine there. I
>> assume
>> the other tools use the same libraries so I don't expect to see
>> anything different (but I also expect MapServer to use the same
>> libraries too, so it's weird it's having problems). But I will try it
>> in a little bit and get back.
> Abe,
> MapServer uses a highly modified variation of a very old version
> of shapelib which might have significantly different performance
> than the generic version. Note, there are good reasons for
> why Steve did this,and I would not suggest changing it. All
> that aside, I think you should accept that no one else has
> seen this problem, and submit a detailed bug report. If you need
> a prompt fix you could even motivate someone with money though
> I'm sure we will look into the problem if you can provide enough detail
> for us to reproduce the problem easiliy.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
