MapServer 4.4.0 released
Eduardo Patto Kanegae
lists at WEBMAPIT.COM.BR
Thu Dec 2 19:20:44 EST 2004
Thanks Sean,
I think that maybe some basic shapefile functionally could solve my problem.
Do you think is it possible to create a "PHP shapelib wrapper" using SWIG?
best
http://www.webmapit.com.br
ICQ: 303747254
Treinamento em UMN MapServer - http://www.webmapit.com.br/ptbr/?menuoption=mapserver
Fórum MapServer Brasil - http://mapserver.cttmar.univali.br/forum
***Fim da Mensagem / End of Message ***
On Thu, 2 Dec 2004 14:52:20 -0700, Sean Gillies <sgillies at frii.com> escreveu:
> De: Sean Gillies <sgillies at frii.com>
> Data: Thu, 2 Dec 2004 14:52:20 -0700
> Para: Eduardo Patto Kanegae <lists at WEBMAPIT.COM.BR>
> Assunto: Re: MapServer 4.4.0 released
> On Dec 2, 2004, at 2:17 PM, Eduardo Patto Kanegae wrote:
> > Hi Sean,
> > Do I have the possibility of compiling Perl or Python mapscript
> > locally , upload it, and then use this module dinamically?
> > Basically, my problem is that my host does not allow me to use "dl()"
> > function of PHP. So, I'd like to know if a similar exists for
> > Python/Perl/Ruby...
> > thanks
> > ICQ: 303747254
> Eduardo,
> It is unlikely that you can upload a module that will just work
> on the other system.
> For Python you will need to build the mapscript module using the
> system's python program, and it will also require that there is a
> C compiler on board. This will also be true for Perl or Ruby.
> Sean
> Sean Gillies
> sgillies at frii dot com
> http://users.frii.com/sgillies
