chameleon config
nasir mahmood
nasir_pcit at YAHOO.COM
Fri Dec 3 16:52:55 EST 2004
I am trying to install chameleon. There is no readme.txt or configuration help with it. I tried to configure by modifying cwc2 xml-dist file but when I run demo.php, i get following errors,
Warning: copy(/hiberfil.sys): failed to open stream: Permission denied in C:\Program Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php on line 288
Warning: copy(/pagefile.sys): failed to open stream: Permission denied in C:\Program Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php on line 288
Warning: dl(): Unable to load dynamic library 'c:\php4\extensions\' - The specified module could not be found. in C:\Program Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php on line 598
Fatal error: Call to a member function on a non-object in C:\Program Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php on line 626
How to overcome this problem by making configuration correct. Can someone help me?
Regards,
Nasir
Do you Yahoo!?
The all-new My Yahoo! Get yours free!
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20041203/4ca7739d/attachment.html
