MapServer Map Context
Thomas E Burk
teb at MALLIT.FR.UMN.EDU
Mon Dec 6 10:08:08 EST 2004
And/or use the "Add a Comment" link that's at the bottom of every MapServer
documentation page to point out the issue. Comments are passed on to the
documentation author the day we receive them.
Thanks,
Tom
>X-Umn-Remote-Mta: [N] lsv-m.tc.umn.edu [160.94.23.1] #+HF+LO+NM
>X-Umn-Remote-Mta: [N] mx2.magma.ca [206.191.0.250] #+NR+OF (I,-)
>X-Umn-Report-As-Spam: <http://umn.edu/mc/s?DdrvMBm4JH69XjOanSBhJo4M8xRunpAVu>
>User-Agent: Mozilla Thunderbird 0.9 (Windows/20041103)
>X-Accept-Language: en-us, en
>MIME-Version: 1.0
>Content-Transfer-Encoding: 7bit
>Date: Sun, 5 Dec 2004 12:36:01 -0500
>From: Jeff McKenna <jmckenna at DMSOLUTIONS.CA>
>Subject: Re: [UMN_MAPSERVER-USERS] MapServer Map Context
>X-To: Raj Singh <info2004 at RAJSINGH.ORG>
>To: MAPSERVER-USERS at lists.umn.edu
>I've filed a bug for this
>(http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1104). If you notice
>any documentation problems please file a bug in the MapServer Bugzilla
>(component: 'MapServer Documentation')...this helps us keep track of
>them. thanks.
>jeff
>Raj Singh wrote:
>> Thanks Assefa. Your advice worked. The HOWTO should be updated because
>> it seems incomplete.
>> http://mapserver.gis.umn.edu/doc42/mapcontext-howto.html says only to,
>> "Build/install the above libraries on your system adn then build
>> MapServer with the '--with-wmsclient --with-proj --with-php' configure
>> options."
>> --Raj
>> On Dec 2, 2004, at 12:34 PM, Yewondwossen Assefa wrote:
>>> You need to make sure that your build uses USE_WMS_LYR and USE_OGR
>>> flags (you need to build you mapserver/php_mapscript with wms and
>>> gdal/ogr support).
>>> Raj Singh wrote:
>>>> Has anyone used the OGC web map context support in version 4.2.2?
>>>> I'm having a tough time getting Web Map Context support working. I
>>>> have
>>>> proj4, gdal, php, wmsclient and wmsserver support working fine, but
>>>> whenever I test map context support using this code:
>>>> <?php
>>>> dl("php_mapscript.so");
>>>> $oMap = ms_newMapObj("/usr/local/apache2/htdocs/umi5/parcel.map");
>>>> $oMap->saveMapContext("/usr/local/apache2/htdocs/tmp/output.xml");
>>>> I get the following message in my apache error log:
>>>> [error] [client 66.31.41.182] PHP Warning: [MapServer Error]:
>>>> msSaveMapContext(): Not implemented since Map Context is not enabled.
>>>> --Raj
>>> Assefa Yewondwossen
>>> Software Analyst
>>> Email: assefa at dmsolutions.ca
>>> http://www.dmsolutions.ca/
>>> Phone: (613) 565-5056 (ext 14)
>>> Fax: (613) 565-0925
>Jeff McKenna
>GIS Specialist
>DM Solutions Group Inc.
