4.4.0 build ok, but 4 python mapscript tests are failing
didier.georgieff
didier.georgieff at AGRICULTURE.GOUV.FR
Mon Dec 6 10:48:12 EST 2004
Le lun 06/12/2004 à 16:27, Sean Gillies a écrit :
> The unit testing framework works by importing mapscript from
> python/tests/cases/testing.py. You can look in that file to see
> how it is done.
OK. I'll look at it.
> To diagnose if the framework is failing, cd to python/tests/cases and
> try this:
> $ python
> >>> from testing import mapscript
> >>> mapscript.MS_VERSION
> '4.4.0'
$python
Python 2.3.3 (#2, Feb 17 2004, 11:45:40)
[GCC 3.3.2 (Mandrake Linux 10.0 3.3.2-6mdk)] on linux2
Type "help", "copyright", "credits" or "license" for more information.
'4.4.0'
It seems to be fine. Sorry ;-)
> 4.4.0 is what I get. If the testing framework fails on mandrake, and
> you accidentally import another installed mapscript, the version string
> should make it clear.
2 months ago, I installed mapscript from the previous 4.2.4. I'll try to
see if something remains.
Anyway, thnaks for the help.
didier.georgieff <didier.georgieff at agriculture.gouv.fr>
DIDSIT du Bas-Rhin
