chameleon config
Paul Spencer
pspencer at DMSOLUTIONS.CA
Tue Dec 7 10:57:21 EST 2004
Nasir,
there is an installation guide in the docs/html folder (of the cvs
version and maybe beta 3).
Chameleon uses 'chameleon.xml' as its configuration file. You should
copy 'chameleon.xml-dist' to 'chameleon.xml' and edit it as described in
the file (or in the installation guide).
You may want to consider using MS4W (http://www.maptools.org/ms4w) as
everything comes pre-configured ...
Cheers,
Paul
nasir mahmood wrote:
> Hi,
> I am trying to install chameleon. There is no readme.txt or
> configuration help with it. I tried to configure by modifying cwc2
> xml-dist file but when I run demo.php, i get following errors,
> *Warning*: copy(/hiberfil.sys): failed to open stream: Permission denied
> in *C:\Program Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php*
> on line *288*
> *Warning*: copy(/pagefile.sys): failed to open stream: Permission denied
> on line *288*
> *Warning*: dl(): Unable to load dynamic library 'c:\php4\extensions\' -
> The specified module could not be found. in *C:\Program Files\Apache
> Group\Apache2\htdocs\cwc2\htdocs\cwc2.php* on line *598*
> *Fatal error*: Call to a member function on a non-object in *C:\Program
> Files\Apache Group\Apache2\htdocs\cwc2\htdocs\cwc2.php* on line *626*
> *How to overcome this problem by making configuration correct. Can
> someone help me?*
> Regards,
> *Nasir*
> Do you Yahoo!?
> The all-new My Yahoo! <http://my.yahoo.com> – Get yours free!
|Paul Spencer pspencer at dmsolutions.ca |
|Applications & Software Development |
|DM Solutions Group Inc http://www.dmsolutions.ca/|
