Shapefile field problem
Ryan, Adam
ARyan at CO.LINN.OR.US
Tue Dec 7 11:27:30 EST 2004
Abe,
Here's a routine I use to get the header information (field info) from a dbf
file.
// ========== iDbf_fields ==============
// $f is a dbf file path, returns an array of field arrays
function iDbf_fields($f){
$h = fopen($f,"rb");
$a =
unpack("cversion/cyy/cmm/cdd/inumrecs/sheadsize/srecsize",fread($h,12));
fread($h,20); //skip some reserved space
for($i=0;$i<($a["headsize"]-33)/32;$i++){
$fa = array();
$fname = trim(fread($h,11));
$fa["type"] = fread($h,1);
fread($h,4);
$fa = array_merge($fa,unpack("Clen/Cpre",fread($h,2)));
fread($h,14);
$flds[$fname] = $fa;
fclose($h);
return $flds;
When I generate a result table I'll go through the array like this: ($so is
the shape Object)
foreach($flds as $fname => $fA){
$val = $so->values[$fname];
if ($val==null)$val=" ";
$val = str_replace(" "," ",$val);
if ($fA["type"]=="D"){$val =
substr($val,4,2)."-".substr($val,6,2)."-".substr($val,0,4);}
echo "<td>$val</td>";}
Cheers to all,
Adam
> -----Original Message-----
> From: Abe Gillespie [mailto:agillesp at VT.EDU]
> Sent: Monday, December 06, 2004 5:14 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Shapefile field problem
> It's a regular shapefile. I think I've mostly narrowed it
> down. It seems to me (though I may be completely off) that
> MapServer loads the first record of the DBF in order to get
> the field definitions. If the first record has a string
> field and the value is zero length it won't give me the field
> (though the field count is always correct). In addition, it
> won't give me any fields after that either. If, however, I
> make sure that field has some value (a dash, an "x",
> whatever) then the field definition will come in correctly.
> I still haven't narrowed down a problematic number field
> though. Mind you, this is all done in MapServer PHP v. 4.2.0.
> -Abe
> On Dec 6, 2004, at 6:15 PM, Daniel Morissette wrote:
> > Abe Gillespie wrote:
> >> A good amount of fields aren't showing up in MapServer for
> me. I use
> >> the following PHP script to dump out all layers and their
> fields for
> >> debugging. Does MapServer have problems with certain data
> types or
> >> certain values in a row?
> > Are you using a tiled shapefile layer or is this a regular
> shapefile
> > layer?
> > Daniel Morissette dmorissette at dmsolutions.ca
> > DM Solutions Group http://www.dmsolutions.ca/
